Positive Camber After Coilovers
Old Feb 24, 2010 | 01:37 PM
InBox's Avatar
Default Positive Camber After Coilovers
Hellooo,
I installed Nex coilovers on my xb, and looks like it has some very positive camber and the toe seems to be off on the right wheel aswell. Now I know I have to get it aligned, but is there any way I can correct the camber? I read you can remove the bottom bolt on the strut and push it in and then put it back? makes no sense to me, did I do something wrong? I need help!
Thanks.
Old Feb 24, 2010 | 06:10 PM
Zsanz's Avatar
should be a plate ontop of the strut if you loosen the bolts and push the strut in towards the engine on both side after the cars jacked up should help you out.
camber plate should have marks
correct me if im wrong?
Old Feb 24, 2010 | 11:39 PM
BigJohnXa's Avatar
if you get a camber kit wouldnt that fix the problem?
Old Feb 24, 2010 | 11:48 PM
engifineer's Avatar
When you lower a mcstrut setup, you move further into the positive part of the camber curve. Look at the way the tie rod and control arms are laid out, then picture them swinging upwards, and you will see why. This is just one of the reasons over-lowering a car destroys handling.
I have never worked on an xB, but assume there is no stock adjustment up top. If your coilovers do not have camber plates, then a set of camber bolts to replace one of the lower strut bolts on each side will allow the adjustment. You can also most likely get a set of crash bolts from Toyota that will do the same thing (They are just smaller diameter than stock). But probably the same price as a set of camber bolts. I am not a huge fan of camber bolts since they can slip and cause alignment changes, but until I got coilovers with upper plates on the tC I used a set of ingalls and they did ok for a season of autox.
Old Feb 25, 2010 | 12:52 PM
bbszero's Avatar
these are a much better alternative to camber bolts. You get what you pay for!
http://www.directtuning.com/store/pc...06-cus%20.aspx
Old Feb 25, 2010 | 08:20 PM
InBox's Avatar
ok, I fixed the problem. All I had to do was loosen the 2 bolts on the strut, push the coilover in and tighten.
Old Feb 25, 2010 | 10:17 PM
engifineer's Avatar
You need to have it aligned. When you change camber, you also change the toe to some degree. It needs to be properly aligned if you want to ensure that you dont induce excessive tire wear. You can run with a lot of negative camber, as long as the toe setting is not too out of whack.
steeze69
May 24, 2021 02:57 AM
greytc
Oct 26, 2015 07:53 PM
MeDizzy
Oct 8, 2015 03:31 PM
ScionDP
Sep 8, 2015 02:17 AM
alexbarspin
Sep 3, 2015 02:04 AM
