rear camber shimms
Old Feb 17, 2008 | 12:01 AM
swartzautoman's Avatar
Default rear camber shimms
ok its time to get this all pulled together
ive got allot of stuff on the way:
Tein SS+P coilovers
sportmax 16x8 +15 offset
falcon 195/50/16
all im missing is a set of -3 camber shimms for the rear. ive see plenty of people in the past drop names of other members that make them.
so throw me the name of the one you trust the most.
Old Feb 17, 2008 | 02:02 PM
jct's Avatar
jct
http://www.onetongarage.com/
Old Feb 17, 2008 | 02:15 PM
mcfly74's Avatar
Question from a noob...
Are the shims required when you drop down on these coilovers? Or are you just trying to add more negative camber for the look of it? Thanks.
Old Feb 17, 2008 | 06:12 PM
its not required.
but +20 offset is the max recomended for the box.
im not rolling the fenders and ill also be doing a 10mm spacer in the rear (maybe) i just want to make sure i dont rub the fender, + the look is cool.
ive gotten stuff from keoki befor and ive talked to him gain about thease camber shims the same day i started this thread, so im just gona get them from him.
Old Feb 18, 2008 | 02:20 AM
badbasic's Avatar
got mine from keoki
Old Feb 20, 2008 | 03:35 AM
BurxBox's Avatar
Originally Posted by badbasic
got mine from keoki
+1 They work great. took a little to get shipped but happy with the product.
Old Feb 28, 2008 | 03:59 PM
CamoTrav's Avatar
Only use the -3 camber if you need to after rolling and lowering the car to the lowest. Too many times i see people throw camber on cause "its cool." People, use camber as a functional tool to fit wider wheels with low to negative offsets.
The wheels should fit fine and no rubbing with fender rolling. The offset was made specifically for the xB.
I was on 15x7 +13, with a 15mm spacer in the rear (essentially a 15x7 -2 set up) with 195/50 tires. I was lowered on Tein basics ( not all the way down cause I hadn't rolled the fender yet, but i only rubbed when people where in the car and if i hit a bump at a high speed.
Dont me to be an ****...if imcoming off as one.
Old Mar 15, 2008 | 05:22 AM
fusionscion's Avatar
not at all required it... i need it for my setup... so im guessing with larger rims and a lower offset you will rub.. causing for the need to raise up or go camber to tuck
Old Mar 18, 2008 | 03:58 AM
365Motorwerks's Avatar
Van's the man OTG FTW!!
love2accelerate
May 9, 2016 10:19 PM
scionhawaii
13
Jun 19, 2015 03:59 PM
jcraff3
Feb 20, 2015 11:41 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
