Should I get struts for my new Tanabe springs?
Just word to the wise, Your factory struts are designed to last aprox. 18,000-20,000 miles. Usually loss is at such a progressive rate most never really notice the change. If you have lowered the stance of your vehicle an I" to an 1 1/4" id say you would be fine with the original struts till that point of wear shows. However after setting up over 300 Suspension setups in the last couple of years i will tell you a 2" suspension drop will require a stiffer strut. I'm not aware of any adj. struts at this point but i'm sure either Koni or KYB agx will soon foolow. I'm sure Tanabe has a coilover strut assembly much like TEIN does. that would include a strut with an adjustable perch as well.
We always advise upgrading your struts when lowering a vehicle unless the vehicle is fairly new and came equipped with a sport suspension from the factory. Unfortunately, neither Koni nor KYB (the two lines we represent) offer performance struts for your vehicle at this time.
roger@tirerack.com
Sales Representative
Moderator www.scionlife.com To place an order please call 877 522 8473 Ext. 627 or for internet orders through www.tirerack.com, please mention my name in the previous contact field directly above the Place Order button on the Order Summary page for quick, efficient & professional service.
roger@tirerack.com
Originally Posted by scion
I just got Tokico adjustables for the xB JUST came out. Am adding them to the store now...
Darren
Darren
Am I missing something as I don't see these in the store?
Darren
Darren
Forward Motion Motorsport - whether stock struts will last with aftermarket lowering springs has nothing to do with how low you go, its a factor of spring rates.
The Tanabe DF springs have spring rates of 154 / 165
The Tanabe NF springs have spring rates of 115.5 / 137.5
If the spring rates of your aftermarket springs are significantly higher than stock, you're going to blow the stock struts pretty quick. There are springs available that will hardly lower your car, but stiffen up suspension, & blow stock struts in the first month...there's more to look at than just ride height.
kleecker
01-09-2015 02:26 PM
TOY_bB
9
12-06-2003 05:15 AM
TOY_bB
11-29-2003 03:50 PM
