Spring Installation on Scion xB
Old Aug 2, 2007 | 12:43 AM
  #301
chadr225's Avatar
I just finished up the rear suspension in about a half hour which also included sanding and painting the drums and mounting new wheels. I cant thank you enough for writing up this how to. Ill be doing the front springs tomorrow with a buddy of mine so I hope it runs as smoothly as the rear did.
Old Sep 6, 2007 | 04:35 AM
  #302
daneisthegreatest's Avatar
ok so i tried installing my springs tonight but the 17mm "big nut" would just spin and not loosen, i have no idea what i did wrong, its like the whole shock was spinning and there was nothing i could do about it...i think i tore the boot, is that bad, or should it be ok??? i am going to take the strut to tire kingdom tomorrow and see if they will loosen everything for me and possibly install the spring on the strut because i cant for some reason...
Old Sep 6, 2007 | 08:43 AM
  #303
lil_blue_star's Avatar
Lay the strut down, grab it by the tube, firmly. Use the impact wrench on a low setting. Once it comes free, the spring will likely "shoot" all of 6 inches. It is capable of launching the disc used to lock it in so watch out. And definantly have a second person when reinstalling it.
The boot will try to spin on reinstall. I tore my boot this way. It's fine, just has a nice hole punched through it from where it got tangled up in the spring. Took my strut/spring combo apart about three times trying to fix it.
Old Sep 6, 2007 | 09:18 AM
  #304
thats the only thing, i dont have an impact gun, those front struts kicked my butt though, i have bagged a couple trucks in my day and i have been a mini trucker for about 5 years now and never had a problem like that...i almost feel ashamed...lol...it seems like everyone else is getting it done on their own and here i am going to tire kingdom (hoping) they will do it for me...grr...
Old Sep 6, 2007 | 07:27 PM
  #305
ok so i got the front finished and in the rear i followed Randodes instructions and had the name brand of the spring right side up but i am not sure if that is right, all of my "dead coils" are at the top of the spring and not the bottom...did i mess up??? let me know so i dont kill myself today...
Old Sep 7, 2007 | 04:22 PM
  #306
Originally Posted by eXciteBox
not one sound has come from my xB after i lowered it. all i hear is my magnaflow . no squeeks rattles or anything. if you use the spring wrap you should be good to go
i cut the wrap in half lengthwise, and did each side of the dead coils where they start to come together
is this how they are supposed to look??? mine dont look like that its the opposite of that, i followed the directions on here and had the words on the spring right side up but it all the dead coils are on the top and not the bottom, any help would be greatly appreciated...
Old Sep 7, 2007 | 06:54 PM
  #307
randode's Avatar
Wagonistas
as long as the lettering is right side up, its fine. Some manufacturers put the dead coils on top, some on the bottom.
Old Sep 7, 2007 | 07:26 PM
  #308
ok cool...thanks...wow the scion god himself, i am so honored : )
Old Sep 14, 2007 | 07:39 PM
  #309
so one last question, i did not cut my bumpstops, is that going to prevent me from getting all of my drop in the front end???
Old Nov 8, 2007 | 02:17 PM
  #310
Grant314's Avatar
Awesome instructions. Used them to put some nf210s on my '06 xA this past weekend. it wouldn't say it was "easy", but I'd never worked on cars before until I got my xA. The rears were no problem as I had already been back there before to install monroe sensa tracs. The fronts as expected were a different story. getting the nuts off top of the driver side strut was difficult do to a lack of space for tool work, and actually getting the first strut back into the car and attaching it back to the lower assembly was a b*tch (definitely couldn't have done it without the help of my g/f, and the 2nd front strut was easier since i knew the right angle to get it to slide back in place). I don't know about other springs, but the nf210s do not require a spring compressor to install, and I only weigh like 160. just needed to apply my body weight and keep balanced while she put the center nut on. i didn't do any before and after measuring, i just knew that I wanted the wheel gap to be even all the way around the wheel and have a smoother ride and that is exactly what I got. ill post some pics once i get my konig 16s on this weekend. thanks to everyone who particpated in this thread, your info was very helpful, and if anyone is trying to use these instructions to put some springs in an '06 xA and have any questions about how I did something, just let me know.
Old Nov 18, 2007 | 06:49 AM
  #311
hieroglyphics's Avatar
for anyone that had the same problem as daneisthegreatest on the front shock, loosing the top nut while it is on the car before you remove it this makes it easier. i had the same problem i tookthe shock out and i couldnt get the spring off because the strut/shock would just spin when i would try to loosen the nut. i had to put it back on the car loosen it then take off again. hope this helps someone.
also for the df210s the dead coils should be on bottom and im sure most people have it this way, although im sure it would work upside down.
Old Dec 27, 2007 | 08:39 PM
  #312
trustmedood's Avatar
Thanks Nacy333!
Old Dec 29, 2007 | 08:48 AM
  #313
PakanaHerruus's Avatar
thanks for the instructions.. helped out alot.. i have a friend the owns a shop out here.. so i took it to have the spring compressed to get it off the strut.. id rather play it safe.. other then that.. everything was pretty easy.. ride feels so much better now
Old Jan 18, 2008 | 09:56 AM
  #314
crubrico's Avatar
thanks for the write-up. it made everything so simple! took me and my bro about an hour and a half for the front and about half an hour for the rear. didnt even need a spring compressor.
Old Mar 27, 2008 | 12:38 AM
  #315
bigskyscion's Avatar
Just need to get past the winter season and all the snow and ice that comes with it...then a new set of TRD springs to carry me down the road.
Old Apr 5, 2008 | 09:18 PM
  #316
leov36's Avatar
i got a question, when i put the 19mm bolts back into the strut assembly, i did not fee the bolt through the front like they were originally, does this matter? i did this because the way i was positioned it was easier for me to feed the bolt from the back to the front.
Old Apr 7, 2008 | 07:56 PM
  #317
ryuji16's Avatar
i dont see what the difference would be... i think both ways would work
Old Apr 14, 2008 | 10:39 PM
  #318
TheQuietThings's Avatar
Did this today on my friends 06 xB
Took 2.5 hours from start to finish
Excellent writ eup!
Old Apr 15, 2008 | 02:55 PM
  #319
biancoxb's Avatar
^ Witnessed it , awesome job
Old May 2, 2008 | 03:40 AM
  #320
tangokillah's Avatar
I have had my df210's installed on my 05 xb for about 3 weeks now. What is the purpose of the black wrapping around part of the spring?
