Spring Installation on Scion xB
Old Apr 30, 2006 | 02:05 AM
  #121
registered_user's Avatar
Nice write up! I printed them and istalled my Tein S with my Brother in Law this afternoon. All hand tools. Took a couple hours but dang, the instructions were spot on! Thank you!
Old May 7, 2006 | 05:04 PM
  #122
JoeBus's Avatar
i installed some h techs today and forgot to put the felt washer back on one side...made it a touch longer to do. Now i just need to get it to stop pulling to the left...but great write up.
Old May 8, 2006 | 03:26 PM
  #123
SuperMario6582's Avatar
great guide, it helped me install some df210s. but now i'm getting this weird sound and i think its coming from the rear. i know it would be hard for somebody to tell what it is without actually hearing it, but can anbody maybe tell me what to check and look for back there?
Old May 8, 2006 | 04:00 PM
  #124
evilBOXevil's Avatar
SuperMario6582 Posted: 5/8/06 7:26AM Post subject:
the springs in the rear usually end up having dead coils....so when the coils compress, they actually touch eachother a little. The touching makes a little creaking sound, usually if you push on your bumper or rock your car up and down. The df210s are supposed to come with black spring wrap. You should wrap this stuff around the rear springs, starting with the bottom and wrap it going up. It's supposed to stop the noise.
I have the same springs, and I wrapped them, but the still creak a little when I get in and out of the car. Nobody like that sound, but its not harmful or anything.
Old May 8, 2006 | 04:13 PM
  #125
its not a creaking sound. its when im driving around that i hear it. i'm gonna see about checking all the bolts and making sure that their all tightened right. maybe this will fix it? sometimes it sounds like it starts on one side and then fades to the other side.
Old May 10, 2006 | 01:30 AM
  #126
I figured it out. It was the brake dust covers in the front rubbing. I guess when I pulled out the strut I bent them forward enough that they would rub. I just bent them back into place and I don't hear that noise at all anymore.
Old May 10, 2006 | 05:59 PM
  #127
BloodySunday's Avatar
i'm going to try it this weekend. wish me luck ya'll
Old May 18, 2006 | 06:49 PM
  #128
KaijyuGaijin's Avatar
I did this install this week. I had some trouble puting the fronts on though... I just took the struts to the Tirekingdom down the street and they my new springs on fo $44 it was nice and easy for me. I came back home put them on and reintalled my windshield wiper assembly.
Thanks man for the great write up!
Old May 21, 2006 | 03:21 AM
  #129
Sliphorn's Avatar
Nice. So how did you remove the windshied wiper assembly? I tried that, but didn't have enought time to fool with it.
I got the back goldlines in fine (xA) but the fronts are going to be trouble. I think I'll need to remove that windshield cowl. Anybody take pics of this, or have advice? Thanks.
Great thread!
Old May 21, 2006 | 05:11 AM
  #130
hayalex6's Avatar
Don't bother, a wrench will work fine.
Old May 21, 2006 | 12:05 PM
  #131
flyerI's Avatar
Just did mine with no problems. A 12mm combination wrench will take care of the nuts on top of the strut towers. Take your time putting the strut back on and get someone to help you as it is difficult to manuever everthing and line up the bolt holes by your self.
Old May 21, 2006 | 04:22 PM
  #132
What do you think?
Old May 21, 2006 | 04:26 PM
  #133
i will put some pics up on the window assembly later tonight.
Old May 22, 2006 | 01:05 AM
  #134
Sliphorn's Avatar
Thanks for the advice. I'm gonna buy a combo wrench and take care of it in the next few days. Meanwhile, I'm driving around half-lowered and feeling...pretty cool...
Old May 25, 2006 | 03:04 AM
  #135
Sliphorn's Avatar
Okay, I did the backs. It wasn't too bad. I also removed the windshield assembly, since I didn't have a combination wrench, but I did have a repair manual.
One thing I noticed...I had some trouble with the ABS wire, I think. It drooled a little bit of fluid from both sides, but not much at all. Is this normal? My car seems to drive fine...
Old May 25, 2006 | 03:13 AM
  #136
DUDE!!! If you're leaking brake fluid at all, GET IT FIXED QUICK!!!
It may seem fine now...till you're exiting the freeway and plow into a truck at 80mph, because your brakes don't work.
Please, get it fixed quick!!!
Seriously. I'm not being an ___ about it. Please, get it fixed.
Old May 25, 2006 | 11:03 AM
  #137
flyerI's Avatar
Did you remove the 14mm bolt that holds the brake line to the back of the rear hub? If not, when the swing arm dropped without the shock to limit travel you probably damaged the lines. Make sure the resivoir is full and go get it checked.
Old May 25, 2006 | 01:56 PM
  #138
Sliphorn's Avatar
Thanks for the quick replies. yeah, I undid the 14mm bolt before letting the swingarm down, just like the directions said. The strange thing is that I followed the directions specifically, and about 1 teaspoon of fluid leaked out of the ABS line of each side. It seemed like a tiny amount of fluid, but in equal proportions and from both sides. I undid the bolts, moved the lines out of the way of the swingarm, and in doing so, a few drops spilled out. After that, no leaking at all. What's the deal with that?
However, I will go get things checked, since that seems to be the pragmatic thing to do. Any other thoughts you folks may have on this would be helpful. Maybe the about details will help out.
I just thought that moving the ABS wire gently out of the way shouldn't result in that moisture leaking out...of both wires? WEIRD.
Old May 26, 2006 | 12:59 PM
  #139
Sliphorn's Avatar
Anyone? I'm still planning on getting it checked. Anybody else have this happen?
Old May 26, 2006 | 01:18 PM
  #140
not me check just to be sure man.
