Spring Installation on Scion xB
Old Jul 30, 2006 | 02:53 AM
  #161
rogcjms's Avatar
NM SCIONS
well i just did this today and i have a question. on one of the instructions it says to face the arrow on the tube for the front strut the same way the forks are. Well i didnt exactly do this, should i be worried? i did everything else right i believe...
Old Jul 30, 2006 | 02:54 AM
  #162
hayalex6's Avatar
as long as you put the top on correctly, to where it's labeld "OUT" and that you matched up the key marks.
If you didn't do that, I'd definetly make sure you do ASAP to avoid damage.
Old Jul 30, 2006 | 03:54 AM
  #163
jpauletteUSAF's Avatar
well, the shock tower is keyed so you can't put it in wrong, so if you somehow put anything in wrong, well.... here's your sign.
Old Jul 30, 2006 | 04:23 AM
  #164
hayalex6's Avatar
check again, it is possible to put it in wrong, not keyed.
Another user on this site did that, and the upper strut mount was torn up due to the key not being in the correct spot.
Old Jul 30, 2006 | 02:20 PM
  #165
rogcjms's Avatar
NM SCIONS
yeah i dont think i put it in wrong cuz you really cant, the rubber pieces are made to go only one way. My dad and brother helped me out so we payed attention to everything (i hope). But i should be fine...my box seems a little more lower on S-Tech's then others but i could be wrong...
Old Aug 1, 2006 | 05:35 AM
  #166
rogcjms's Avatar
NM SCIONS
im probably going to check every bolt this weekend to make sure that they are all tight. oh i got a question: On the rear springs is there a way you can install them upside down? the S-tech's i got already had that brown wrap towards the bottom of the springs so i put that side on the bottom. This is my first ever lowering job and im making sure i dont run into any probs in the future, so i dont have to take everything apart again cuz man it took so long for us!
Old Aug 1, 2006 | 09:21 PM
  #167
xA_Factor's Avatar
This man speaks the truth. ^^^
Old Aug 10, 2006 | 08:40 PM
  #168
jct's Avatar
jct
that user does have a name here <<< haha
6th and 7th posts down...
https://www.scionlife.com/forums/vie...asc&&start=100
Old Aug 10, 2006 | 08:50 PM
  #169
hayalex6's Avatar
sry bout that, forgot who it happened to.
Old Aug 10, 2006 | 10:04 PM
  #170
1epoXyBox's Avatar
Here is my tein install if it helps:
https://www.scionlife.com/forums/vie...087&highlight=
Old Aug 11, 2006 | 04:38 AM
  #171
rogcjms's Avatar
NM SCIONS
i didnt cut the bump stop. was i supposed to??? the Tein instructions say to do it. Gonna go to Toyota tomorow for an alignment, maybe have them check it all out and see if its 100% good.
Old Aug 11, 2006 | 07:37 AM
  #172
1epoXyBox's Avatar
I cut mine, but most people on here say it is not required. You will probably be fine, enjoy the springs.
Old Aug 12, 2006 | 01:57 PM
  #173
silidget's Avatar
Just installed the H-Techs using the instructions.
Very easy job!!! Thanks
Old Aug 14, 2006 | 02:53 AM
  #174
ecountz's Avatar
Default Awsome write up
Great write up and awesome follow-up responses with dos and donts made install a breeze. Thanks
Old Aug 14, 2006 | 03:14 AM
  #175
nikkisantoro's Avatar
is anybody concerned about tire wear? what about camber kits?
Old Aug 19, 2006 | 02:03 AM
  #176
rogcjms's Avatar
NM SCIONS
i dont think you really have to worry about tire wear unless you dont get an alignment after you lower it and drive like a race car driver, should be all good. Im glad i decided to lower mine and will never go back to stock again!
Old Aug 24, 2006 | 01:32 AM
  #177
swede's Avatar
Are my springs on upside down? In another forum someone said that they were on upside down....
Old Aug 24, 2006 | 01:44 AM
  #178
pandaslayer's Avatar
they're fine. that person doesn't know what their talking about.
Old Aug 24, 2006 | 01:49 AM
  #179
swede's Avatar
Yeah, that's what I thought too.
Thanks!
Old Aug 24, 2006 | 01:52 AM
  #180
randode's Avatar
Wagonistas
if there is lettering on the spring, make sure the lettering is right side up.
