Strut Problems
Old Jun 28, 2005 | 08:33 PM
sprslug_182's Avatar
Default Strut Problems
If anyone can help me out it would be greatly appreciated. I am trying to put my stock suspension back in until I get my refund. I already put the rear springs in and am having a terrible time with the front struts. I first removed the air strut and had my buddy chris put the bearing plate back on the factory strut. I then inserted the top of the strut in place and put a coupl eof nuts on just hand tight to hold it in place. Then, I pushed down on the steering knuckle to line up the strut to the knuckle, with NO LUCK. The I took the sway bar end link off to allow the lower control arm to drop down more. This still didn't help, so I tipped the leaned the steering knuckle out towards myself in order to allow the strut to slide into place. I got the bottom bolt in and when I went to tip it inward to get the other in, I heard a clunk, the end of the axle pulled out IM GUESSING, and it was hitting on the boot. Let's just say I'm still looking in my front yard for a few tools. I went inside to sit and rethink my strategy. I came back out and leaned the knuckle out a bit more, and the axle when right back in. By this time, I don't know what to think. Im am stuck and I am not sure if the axle should be allowed to do this. PLEASE ADVISE!!!!
Old Jun 28, 2005 | 09:16 PM
I think this is crap that we can't see anything technical until we have 50 posts. what is all that about? I come here when I need help and I can't get it? How communist is that to keep information from the very people who need it the most?
Old Jun 28, 2005 | 09:21 PM
TheScionicMan's Avatar
Communist? You can get access to the service manuals if your a Premium Member. Sounds more like Capitalism, to me.
Hope someone can help you with your problem...
Old Jun 28, 2005 | 09:30 PM
johncal's Avatar
See, that's what I love about communism, everybody thinks they owe them something.
Johncal
Old Jun 28, 2005 | 09:34 PM
Spider13's Avatar
The axle should pull out like that. Just make sure it didn't rip the boot. If it went right back in your should be ok. BTW if you use a long crow bar or something to push the lower arm down it makes putting the struts in alot easier.
Old Jun 30, 2005 | 04:44 PM
Mostly, I just need to jack up the other side, my buddy chris helped out with that one. Finally got all the factory crap back in, I went to get an alignment cuz i could feel the toe is off. I can hear the tires grabbing on the freeway. the dealer tried to tell me it was fine, but I knew I had aligned it after I bagged it, but I wasn't gonna tell them that.
Renike
Mar 1, 2015 10:40 PM
xa007xa
Feb 22, 2015 02:56 PM
AxRxP
Jan 25, 2015 08:40 PM
A1tc2
Jan 14, 2015 02:43 PM
hampton1100
Jan 2, 2015 08:13 PM
