Tein H.Tech Installed. Before & After Pics
Old Mar 25, 2007 | 03:54 PM
  #41
mattxb's Avatar
Even though the H-Techs don't lower that much, it still makes a world of difference in appearance.
Old Mar 25, 2007 | 05:44 PM
  #42
burstaneurysm's Avatar
Looks great, the H.Techs clean it up way more than I was expecting.
Old Mar 26, 2007 | 03:04 PM
  #43
berooobeee's Avatar
burt, has the ride with the new springs gotten softer, or is it harsher?
Old Mar 26, 2007 | 05:09 PM
  #44
The ride is about the same, comfortwise. It hasn't gotten harsher, but it isn't noticeably softer either.
However, the handling and stability has improved quite a bit.
Old Mar 26, 2007 | 08:58 PM
  #45
berooobeee's Avatar
oooo good, im gonna buy me a set.
is it an easy install? do you have experience installing springs? i have no experience and figure if i use the tech guide and a friend, i'll hopefully be okay.
Old Mar 26, 2007 | 09:26 PM
  #46
mattxb's Avatar
The first time I did a spring install myself, I used the tech guide and didn't really run into any issues. The only problem I had personally was getting the nut off the top of the front strut. I ended up going to this dudes house who had air tools. He just zipped it off for me and I was good to go.
Old Mar 26, 2007 | 09:43 PM
  #47
ryuji16's Avatar
yea, def. read the tech article and have one or two buddies with you. also have 2 jacks on hand, and jackstands of course.
Old Mar 26, 2007 | 09:50 PM
  #48
Yea, the biggest pain was reassembling the strut with the new spring on it. See if you can rent a spring compressor somewhere, that would help you immensely. Otherwise, it's a pretty straight forward install.
Old Mar 27, 2007 | 02:28 AM
  #49
Chiguy_2002's Avatar
The rear springs are really easy, even if you replace the rear shocks, still easy. Jack up the rear, put on jack stands. Remove wheels. One bolt on the bottom that connects the rear shock to the rear suspension. One bolt on top if replacing the shocks, per side Takes 30 minutes at most .
The front springs are a little harder. Jack up the front, put on jack stands, remove wheels. Two bolts on bottom, three up top per side. The hardest part is getting the nut off the top, I loosened the one up top before dissasembling. I also had spring compressors. Makes life easier. Fronts probably an hour or two, tops.
This is the complete walk through for springs:
https://www.scionlife.com/forums/vie...769&highlight=
Old Mar 27, 2007 | 02:30 AM
  #50
^ You don't even need to remove the rear wheels to do the rear springs.
Old Mar 27, 2007 | 02:31 AM
  #51
Nope, not at all, makes it easier though...well for me. I did the rear shocks also. The ride is firm, but not bouncey, much more ideal ride than stock. I have the Monroe 5987 Shocks...
Old Mar 27, 2007 | 02:48 AM
  #52
^ I'm running the exact setup.
Old Mar 27, 2007 | 07:56 PM
  #53
berooobeee's Avatar
^^^ i got the monroes also. they help.
jdlong
May 17, 2018 05:20 PM
mischman
Sep 15, 2015 03:38 PM
Ismvelas2
Aug 17, 2015 02:22 PM
ilikepinktacos
Jul 11, 2015 10:20 PM
HATEnFATE
Jul 11, 2015 01:35 AM
