underbody braces
Anybody ever bought a type II brace off ebay?
ebay brace
Pretty inexpensive but are they solid or hollow? The Tanabe brace is hollow but it has two small supports inside of it.
ebay brace
i have the cusco lower arm bar, and yes it does work, aside from what people say, lower arm bars do help with steering and mild handling on the xB. Def quickened up my steering and odffered handling improvements, i say go for it
yeah uhh ... the picture above for the cusco braces are actually not for the xB, those are just some representations from another car's setup.
check out my old write-up on the cusco type II frame brace here: https://www.scionlife.com/forums/vie...093&highlight=
i love it. the sparkling blue is awesome.
the megan bar is amazing. just make sure you grind down the mounting cups so you don;t get stuck on a speed bump. if you are stock height this is an unneeded step. but i ground teh shat out of mine and still scrape. cons of riding low.
I have the GT spec front chassis brace and TRD rear frame brace and the combination of both makes for incredible handling. My car corners like a housefly, that also has partially to do with the strut bar and rear sway bar, but its the combination of parts that really helps to stiffen out the chassis. I say get the quality name brand, the big companies do the correct R&D so i would go with something that is tried and tested, not copied.
