bbs rs?
i found some bbs rs there 16x7 et +50 i wanted to put them on my xb but i dont know how they would fit...would i need spacers would they poke out? my plans r to make them 16x8 in the front and about 16x9.5-10 in the back but if i buy new lips i wouldnt kno if they would fit..any info would be appreciated
depends on if you're changing the outer lip or both and just keep the face. changing the lip will change the offset since offset is measured from the center of the wheel and changing the lip will change the center.
If your going to re-build them, then you'll be fine, if you choose the right offset. What look are you trying to acheive? Do you want to be totally flush with the fenders? Or do you just want more lip without any rubbing issues?
I want more lip with no rubbing issue..I want to get the biggest lip that I can on them but I don't want them to poke out crazy..the front is only gonna be like a 1in lip so I'm not to worry bout that its just the back...wat would b a good offset for wat I wanna do?
with +50 your not going to get the lip you want, and if you want a BIG lip the wheel needs to be wider with a REALLY low offset. chances are you want about a 8-10 inch wide wheel with about an offset of 10-30.
your DEFINATLY going to rub.
rbwheels has a set of BBS RS' 15x7 +25 and the lip is still tiny on those. check it out
http://www.rbwheel.com/index.php?mai...0f574d3e3f1168
Okay I found a set that are 16x7 etc 33 nd 16x8 et30 would I be
able to put a 2.5-3in lip on either one of those for the back? Ive seen a xb wit 17x9.5 bbs rs in the back but he had a -3 camber on it nd im not sure of the offset...If not wat size offset then?
TCpete
Scion tC 1G Wheel & Tire
483
Apr 13, 2010 03:12 PM
mynameisphunk
42
Apr 6, 2005 06:59 PM
