Best wheel size with NO drop
Old Oct 27, 2008 | 09:18 PM
dba900's Avatar
Default Best wheel size with NO drop
As the title suggests, what's the best wheel size if you aren't going to drop your box? By "best," I mean the size that fills up the wheelwell gap. We often have lots of people/stuff in the back of ours and ground clearance has been an issue at times.
Thanks,
David
Old Oct 27, 2008 | 09:37 PM
burstaneurysm's Avatar
If you increase the tire profile a bit, you'll fill the wheelwell better and see a cushier ride.
Old Nov 12, 2008 | 01:44 AM
bB2NER's Avatar
Music City Scions
If you try to fill the wheelgap by using taller tires you gear ratio and speedo will be off.
For the best ride 17"wheels or smaller will yield the best ride quality. Use a 215/45/17 on 17X7 or 7.5 wheels with 40 mm ish offset and you should be golden.
Old Nov 12, 2008 | 12:57 PM
dba900's Avatar
So, 205/55-16s would also be a good option? I assume that 16s would have a little more "cushion" for potholes and the like?
Thanks for the help!
David
Old Nov 12, 2008 | 07:19 PM
bB2NER's Avatar
Music City Scions
You can use this tire/wheels size calculator for coming up with the right combo for you needs. It gives you a bunch of info. http://www.rims-n-tires.com/rt_specs.jsp?postId=906
scionlife
371
Jun 2, 2015 11:00 PM
rain7905643
Mar 14, 2015 12:48 AM
umnitza
Dec 1, 2014 06:26 PM
BUzzBUcket
10
Oct 12, 2003 07:19 PM
