fender lip? cutting vs. rolling
Old Nov 2, 2004 | 08:03 PM
stankubrick's Avatar
Default fender lip? cutting vs. rolling
Anyone have experience with cutting/trimming the fender lip as opposed to rolling it?
Old Nov 2, 2004 | 08:11 PM
squirrel's Avatar
Rico, I'm pretty sure that if you cut the fenders on these xBs, you'll loose beaucop structural rigidity. The next thing you know, you'll have wavy fenders and quarter panels. I would roll them to keep the rigidity.
Old Nov 2, 2004 | 08:16 PM
ooh, didn't think of that, thanks.
I was just tinkering with the idea of meatier/taller tires like signalXB (posted the sweet pic with the JLine wheels). I think he mentioned something about trimming some of the lip....
Old Nov 2, 2004 | 11:42 PM
Jeff_Chicago's Avatar
Go get a Louisville slugger and roll them! Easiest way, and works perfect!
Old Nov 4, 2004 | 07:21 AM
signalxB's Avatar
i cut those suckers off about 12mm. real clean and took a hell of a lot less time then if i rolled them. still pretty solid since it double up on the edge.
Old Nov 4, 2004 | 08:23 PM
What did you do so that the cut edge doesn't rust? Is the edge sharp? Your setup looks awesome....Where are those pics man!
Old Nov 4, 2004 | 09:39 PM
Minsk99's Avatar
I did the same thing. So far no problems. To stop rust just get some clear coat or touch-up paint.
Old Nov 5, 2004 | 06:33 PM
Prettym1k3's Avatar
If you're really ballsy, get a heat gun and a fender roller, and pull those bad boys.
My friend did his S14 and his my other friend did his S13. Both didn't come out REALLY clean, but for racing purpose, and since both cars are running 10's in the rear, it worked out well.
Old Nov 5, 2004 | 09:02 PM
ScionVan's Avatar
If you cut your fender lips, you can only remove so much, and sometimes it's still not enough, so you end up rolling the fender lips still. So it's sometimes a better idea to just skip the intermediate step and roll from the fenders from the get-go. To prevent major paint cracking problems, just score the paint with a razor blade along the inside edge, then put a piece of thick tape over the fender lip (the part you will be rolling). If it's super cold outside, and/or you're not sure what you're doing, then use a heat gun to heat up the fender lip as you go. Then just use the fender roller tool and take it easy... a few extra minutes now will pay dividends later. By scoring the paint, you ensure that any cracking or peeling should stop right at that line, and the tape will keep the paint from totally coming off... but even slight paint cracking is inevitable, so don't be too afraid when you see it chip off a bit.
Old Nov 5, 2004 | 09:23 PM
Thanks Van, I think I'm just gonna roll em now. Scoring the edge is exactly the tip I didn't know I was looking for!
Old Nov 8, 2004 | 08:00 PM
Prettym1k3's Avatar
If you use a fender roller, you won't need to score anything.
Old Nov 8, 2004 | 09:47 PM
I got this info from a local bodyshop:
"I do have time to roll fenders, but unfortunately i am not able to do Scion XB's....the inner fender lip has some sort of extra lip that is painted onto the lip and has some sort of glue residue....Once u try to roll the inner fender lip the paint and glue will separate from the inner lip and reach out to the outside of the car."
Old Nov 8, 2004 | 09:58 PM
Prettym1k3's Avatar
Haha...
In other words...
"I can't do it."
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
r3aper503
May 15, 2015 06:31 PM
mvez
Scion tC 2G Wheel & Tire
Apr 1, 2015 12:37 AM
Opr8r
15
Oct 6, 2003 05:07 PM
