fitting new rims
Old Jan 31, 2007 | 06:18 PM
heyitzdrahcir's Avatar
Default fitting new rims
okay. I'm new to modifying cars and all that and I've searched for this answer, but I just didn't get what i want to hear. I have a stock suspession on a xA. I'm going to get Eibach sportlines and koni yellows and then I want to get rims. The rims I want are either Rota Track R's or GT3's in 16x7 +40mm. The only thing I'm confused about is the offset. Will I be able to mount the rims the way they are and would they look flush with the finders? Will I need to get spacers? If so, can you remommend me some so I know what I need before I get into it. thanks guys.
Old Jan 31, 2007 | 07:00 PM
smoke20's Avatar
you'll need some pretty thick spacers to get those to be flush
Old Jan 31, 2007 | 07:01 PM
how thick? and they'll look nice and flushed right with no rubbing?
Old Jan 31, 2007 | 07:05 PM
randomsuper's Avatar
i'd go 10mm up front and 15mm in the rear. it will be flush enough imo, but it depends how close you wanna go. what size tire are you planning on using?
Old Jan 31, 2007 | 07:19 PM
smoke20's Avatar
the more flush you want it, the more work you're going to have to do, rolling/pulling fenders and adding more camber
You can try the otg stacked spacers in the rear...20mm and it's easier than putting a wheel spacer on and adding longer wheel studs, though you'll end up having to do that in the front anyways.
Old Jan 31, 2007 | 08:43 PM
I think i want 205/45/16 or 205/40/16. I'm not sure which is better dealing with the odometer and all. I want a little more meat on the tires but at the same time I don't want as much as stock. I'm also not sure which tires I want either so I kind of need help choosing that. I live in SoCal so I dont need to worry about snow or anything. It's mostly sunny weather and we get a bit of rain so I want tires that are affordable, grip really well in dry and pretty well in rain.
edit: as far as going flush goes. I'd like it flush enough so it's not obvious that i'm not filling in the wheel gap. I don't want to have to roll fenders or anything. I basically want to go with lightly modded. I just want it to look decent.
Old Jan 31, 2007 | 10:00 PM
10mm up front, 15mm in the rear. you won't be disappointed. as for tire size, i say 205/45. more tire is better on the xa, especially if you're going to run a smaller wheel. i have 215/45 falken ziex on my 17's and i love them. good all around street tire.
Old Jan 31, 2007 | 10:03 PM
cherryBox's Avatar
Don't buy spacers. Buy rims that fit.
If you must buy rims that do not fit, by all means use only hubcentric spacers.
Old Jan 31, 2007 | 10:48 PM
What rims fit then? I like the looks of Rota GT3's and Track R's I thought they'd fit.
Old Feb 1, 2007 | 12:31 AM
Boxer_Rebellion's Avatar
It's a matter of how well they fit
I would skip all the hassle with spacers and get the new et15 16x8 SportMax 501's in red, get some OTG 10mm shims to make the rears even with the fronts, roll your rear fenders (which I just had done, HUGE difference) and you're done.
It will look way cooler, be less expensive and much safer.
Old Feb 1, 2007 | 05:22 AM
the thing is.. i see it two ways.. i have a car slammed on some deep dish tiny rims... or i have some medium sized "racey" rims. i just want a simple flow so i was looking for gt3's in silver. i just wanted to know what i'd have to do to get it to look decent with the suspension set up i'm planning on getting too
Old Feb 1, 2007 | 11:58 PM
Just do some searches on here, you'll see alot of the Rotas or similar honda-offset wheels on xA's, and you can see what they used (if anything) to improve the stance.
Old Feb 2, 2007 | 05:13 AM
bB2NER's Avatar
Music City Scions
The fronts already stick out quite far so I would do the 10 mm OTG rear spacers behind the backing plate to bring them out more to match the fronts. Then go with the 35mm offset wheels all the way around so you can rotate the tires properly. The proper size 16 inch tire would be 205/50/16 and would be just slightly taller than the 185/60/15's you will be replacing. Here is the link to the tire/whell calculator I got this info from.
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
mama22
Mar 20, 2015 04:59 PM
Sagara09
Feb 28, 2015 06:58 AM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
Flipper
Nov 12, 2003 02:39 PM
