help with rub on xa on 19x8
Old Mar 31, 2006 | 01:32 AM
cheftbonez's Avatar
Default help with rub on xa on 19x8
I just got my 19x8 g-racing sekis, I tried to install them today but the car would not move because it was sitting on the lower bar of the suspension. what do I need to do because they look banging on my ride. Is it just wheel spacers that will do the trick and how much or should I go with the one ton garage shims looks like that is what a lot of people are using. The tires are 215/35 and what is rubbing is actually the lip on the back of the rim the tire is clear. :nails[/img]
Old Mar 31, 2006 | 04:31 AM
MyBoX's Avatar
I would think your offsets are higher than 30 otherwise you wouldn't have this problem, I would say start with the OTG shim kit and if that didn't fix the problem keep them and just add 15mm spacer and that should make your wheels fully flushed !!
And I think its a bit to late but with 19s you should get 30 series !!
Rob54Monty
Jan 20, 2016 01:41 PM
terrye
Sep 26, 2015 12:24 AM
meowtc
Mar 5, 2015 02:28 AM
BoomBox757
Feb 23, 2004 04:47 PM
pmpnxb
Jan 21, 2004 02:45 AM
