hub centric rings
One Ton Garage makes them, I think Keoki does too (I got my rears from him). Ichiba makes them as well. The Ichibas come with longer studs. I've got 5mm FK spacers up front. FK is a German company that makes parts for the Euro tuner market. But we share the same bolt pattern as some VW's (4x100). The hub opening for the FK's is 57.1mm, I think our hubs are 54.1mm, so they're a great match. Plus they were only $35.
Hope this helps.
Hope this helps.
does anyone know if hub centric rings will help vibrations that i am getting at the steering wheel? i already went in once again for the balance of the wheels. turned out 2 were not right. but still after i got that fixed. i still get vibrations 65mph + and it get's harsher as mph rises.
Probably not. The vibration is coming from either the wheels or tires (or a bad strut/shock). I would suggest taking the wheels that were incorrectly balanced but fixed and mount them on the front and see if that helps. Other than that, I might suggest a high-speed balance where the wheels are balanced while still on the car.
what's the difference between a regular balance and a high speed balance?
Hubcentric rings are designed to do pretty much what they did for you, help guarantee that the entire rotating assembly is as round as possible. It rings aren't used, or the wheels themselves aren't hubcentric ($$), then you are relying on the conical lug nuts to perform the task. The problem is that most people hand tighten the nuts, then lower the car to the ground to torque them to final spec. This can actually gall the lug seat of the wheel, or actually bend the stud.
For best possible fitment when rings aren't used, torque the nuts while the car is in the air, in increments. Use a buddy with his/her foot on the brake to keep the wheel from spinning.
I get the impression from rygar's 1st post and possibly his second, that he is thinking of spacers, not rings.
Originally Posted by octagon
Auto Zone? off the shelf. Auto Zone sells hubcentric rings? Cant find my raised eyebrow emotion.
ok, were they plastic or aluminum? I have work eurolines showing up this week
15x8 +35 and i know i need the inner bore spec, so i assume autozone can hook me up?? Secondly if the wheels are torqued down in star pattern will the problem of not running hubcentric rings go away??
There is no why to eye ball centering a wheel. the holes in the wheels for the studs are always bigger than the studs themselves. The only thing that will center a wheel is a hub centric ring.
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
