info on rims please
what specific specs should i look at while checkin out rims? (havent even payed attention to how many wheel bolts are on my xA O.o) but anyways, if its 4 like i think it is, is that all i have to look at or do some manufacturers change the distance between the 4 bolts? like do i have to worry about manufactuers designing the bolts to be different distances from each other? or is it all universal. 4 bolts fits with any other 4 bolt?
it's a 4x100 and ideal offset is anywhere from 36-42. unless yer lookin for the deep dish look. it all depends on what your lookin for. and just remember the bigger the rims the more expensive the wheels and tires will be. duh .
Originally Posted by UndyingVisage58
now on that note where can i find 4/100 rims? or could i get a list? info etc etc. thanx :D
Just be careful....alot of the wheels they may show you are "Out of Stock" and some of them aren't coming back.
4x100 is one of the most common bolt hole so. very easy to find. r u looking for cheap rims or what? for cheap wheels check out www.wheelmax.com , www.cheapwheels.com , www.ebay.com , and a whole lot of other places.
Wow, Tirerack.com is an awesome site!
I need to save up $$$$ to buy these for my xA:
http://tinyurl.com/4fzj9
http://tinyurl.com/67ubb
Originally Posted by matt_a
Exactly. Also as a general rule, the taller the rim, the harsher the ride will be. Those factors are why I decided to only upsize to a 16" rim. The wheels and tires cost less than comparable 17"s or 18"s, plus they weigh less (more power and better gas milage). Also, I live in PA (REALLY CRAPY ROADS) so I didn't want more than a 16" for ride quality.
http://www.tirerack.com/tires/tires....ero+Nero+M%26S
I'm just curious what you drive on, impressions, how many miles driven, etc.
Thanks BK! Here's a good link to see how much different your "new" wheels & tires will be Vs. the stock setup.
http://www.1010tires.com/TireSizeCalculator.asp
Ideally you want them to be less than a couple % off. Mine are only off by 1.38% (205/50/16).
goatbelly
Jul 12, 2015 10:13 AM
