largest tire on a 17" wheel
Old Apr 30, 2008 | 10:49 PM
statass's Avatar
Default largest tire on a 17" wheel
I have 4 205/40/17's on my XA with stock springs and struts.
I need new tires.
Whats the largest tire i can use?
I believe 215/45/17 are roughly the same overall size as the stock 185/60/15...
Can i go larger without rubbing? I'm looking for comfort and to fill the wheel well a bit (the 205/40/17 look kinda small)
what about a 205/55/17? or 215/60/17?
i dont know much about tires...?
Thanks
Old May 1, 2008 | 06:36 AM
hotbox05's Avatar
215/45/17 is larger than stock diameter
205/40/17 is undersized
for oem diameter 17's you want
205/45/17 OR 215/40/17
you should be able to easily run 215/45/17 if you aren't slammed
if you want comfort go with 16's theyre bigger than stock , have a decent selection and the tires are MUCH cheaper and will ride much better than any lo pro 17 will
Old May 1, 2008 | 10:28 PM
bB2NER's Avatar
Music City Scions
I would not try going any larger than 215/45s.
Old May 2, 2008 | 01:20 AM
statass's Avatar
Is there more clearance in the back...?
What are the complications if i put larger tires in the back.
see, i inherited the rims and tires from a friend. The fronts have maybe 5000 miles on them and in great shape but the backs are pretty bad.
I was gonna replace all four with the same 205/40/17 rather than just the two rears.
I have read that some people have bigger tires in the back?
Thanks
Old May 3, 2008 | 04:07 PM
statass's Avatar
bump
can i put a larger tire on the back?
205/40/17 on the front and 215/45/17 on the back?
Old May 3, 2008 | 07:48 PM
CBSIMONSEZ's Avatar
Originally Posted by statass
bump
you can but its gonna look really out of place. The back end is going to look jacked up while the front end is going to be kissing the ground.
Old May 5, 2008 | 08:45 PM
statass's Avatar
yeah....and i didnt think what would happen when i rotate.
Old May 13, 2008 | 10:19 PM
DiscountTireDirect's Avatar
215.45.17 is a little large, if you don't mind modifying you should be able to get them to fit. You're speedo will be off a little though. As stated above ideal would be a 205.45.17 or a 215.40.17
Old May 15, 2008 | 03:37 PM
Leo_EdgeRacing's Avatar
When I had my xA, I was dropped on Tanabe DF210's with 17x7 ET 42 wheels and I ran 215/45R17 with no issues at all. The ride was comfortable in my opinion, but 16's will be much smoother of a ride.
Old May 15, 2008 | 05:16 PM
Big_hungry's Avatar
I had 205/45's and they rode great much better than the 40 series.
Old May 16, 2008 | 09:16 PM
PAboX's Avatar
here's a cool website you can play with to compare different size wheel and tire combo's
.http://www.rims-n-tires.com/rt_specs...2=1st%20choice
evolving_machine
Oct 21, 2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
evolving_machine
12
Jan 18, 2016 08:41 PM
terrye
Jul 11, 2015 11:54 PM
evolving_machine
Jan 13, 2015 08:04 PM
