Miata Wheels
Old Aug 19, 2009 | 12:29 AM
sajack's Avatar
Default Miata Wheels
Will 15" Miata wheels fit my xB? I guess the offset would probably be wrong, but is the bolt pattern a 4x100 like my Miata?
Old Aug 19, 2009 | 01:24 AM
RedneckwithanxB's Avatar
They will fit around the lugs... clearing the calipers might be a different story...
Old Aug 19, 2009 | 01:56 AM
DsTC's Avatar
well check the offset, hub sizes, and bolt pattern, if the miata hub size is bigger or the same to your scion, then it'll work as long as the offset clears the caliper, and the bolt pattern is the same...
Old Aug 19, 2009 | 11:12 AM
sajack's Avatar
What is the offset on my factory stock xB wheels in mm?
Old Aug 19, 2009 | 02:08 PM
burstaneurysm's Avatar
It's either 38 or 42, I can never remember.
Old Aug 19, 2009 | 02:26 PM
Old Aug 19, 2009 | 05:06 PM
sajack's Avatar
I believe the Miata wheels have a 45mm offset. Even if they fit, I wonder what that would do to handling?
Old Aug 19, 2009 | 06:07 PM
SR20DE_MAN's Avatar
Everythihng else will fit, but like already stated, your front calipers would probably crash against the spokes. When I had some 15x6.5 +38 Rota Grids on my box, the spokes just barely cleared the calipers. I'm talking about 1 to 2 mm of clearance. They were that close.
Old Aug 19, 2009 | 06:32 PM
the question above (38 or 42) refered to stock xB steelers
Old Feb 29, 2012 | 01:33 AM
Hites's Avatar
Was it ever determined whether or not the 99-00 Miata 15" alloys fit?
Old Feb 29, 2012 | 09:56 AM
sajack's Avatar
Yes, in fact, all 1990-2005 Miata wheels will fit. The center hub opening is 54.1mm, exactly matches the Scion too. There are lots of Miata wheels on the used market, so this is a relatively cheap mod that eliminates those dorky plastic wheelcovers.
We are running 2002 Miata 15" alloys on our 2005 xB. It drives and handles great.
evolving_machine
Oct 21, 2023 01:16 PM
rnaz1017
Mar 20, 2015 09:30 PM
EcoxA
Mar 18, 2015 03:45 PM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
Docofmind
9
Oct 23, 2003 04:08 PM
