new wheel problems
Old Jun 9, 2007 | 11:13 PM
Big_Bird's Avatar
Default new wheel problems
hey all, i just got my 15x6.5" wheels mounted, i had them balance it twice and it felt good. But then, oddly, and randomly, the wheels would shake, not the steering wheel though, just the wheels, which makes the car shake, about a minute later it stops, it happenes periodically, i had them retourqe the lugs and it helped for about an hour then it happened again. I cant figure why and the wheel shop deosnt open until monday. anny help?
Old Jun 9, 2007 | 11:26 PM
trdtcpr's Avatar
just a thought but maybe the scews are peeled and the lugs are not holding in place i don't know what else it could be.
Old Jun 10, 2007 | 02:01 AM
Tomas's Avatar
Admin Emeritus
You DID use the proper hubcentric rings, didn't you? Not just depending on the lugs to center and hold the wheels...
Tom
Old Jun 10, 2007 | 02:07 AM
Big_Bird's Avatar
yep, the guys there tested about 5 and got one that fit snugly, that's why i cant figure the problem
Old Jun 11, 2007 | 01:56 AM
Amoxaphobic's Avatar
Did you by chance get an alignment when you got the wheels mounted? They might have messed something up, like the tie rod. That could cause it to shake randomly.
....Just a thought.
Old Jun 11, 2007 | 02:02 AM
Big_Bird's Avatar
i was thinking that amox, but i never had any prob with my previous 2 tire set ups. i dunno, im taking it back in after class tomorrow morning, really hope they can fix it so i can enjoy my first set of rims. cause so far they suck
Old Jun 11, 2007 | 07:04 PM
Big_Bird's Avatar
the left rear tire isnt completely round, so they way it was mounted on the wheel, it made it like an egg, so they took it off and mounted the hi/lows tgether and moved it to the front. seems to be fine now, but havent really driven today, so we shall see.
Old Jun 11, 2007 | 07:47 PM
Tomas's Avatar
Admin Emeritus
Ah! Makes sense. The wheels and tires not being perfectly round is fairly common, and mounting them so the high points are opposite will usually take care of the problem.
The wheels/tires on my box were purchased at the same time, and the vendor automatically mounted all of them that way, and they are smooth as glass.
Good luck!
Tom
Old Jun 12, 2007 | 10:48 PM
Big_Bird's Avatar
i really cant tell if it's anybetter. the roads here are so bad, sometimes i think i feel it, other times i cant feal anything.
Old Jun 13, 2007 | 01:36 AM
Metro273's Avatar
If the tire is "egg-shaped", it needs to be replaced. A tire shop should have told you that cause at my dealership, we would tell you that the tire is no good and we would show you why...
Old Jun 13, 2007 | 03:49 AM
Tomas's Avatar
Admin Emeritus
http://www.tirerack.com/tires/tirete....jsp?techid=17
Old Jun 19, 2007 | 02:47 PM
Big_Bird's Avatar
well problme still persists
so i am sending them back to tire rack
Old Jun 19, 2007 | 10:06 PM
Tomas's Avatar
Admin Emeritus
Old Jun 21, 2007 | 01:26 AM
xBster's Avatar
Sounds like you did the right thing...I don't like shakey wheels at any speed...especially when they are new....let us know how it works out for you!
Old Jun 22, 2007 | 10:09 PM
ayS's Avatar
ayS
i have vibrations that i can feel on my steering wheel as well. hopefully i can get those resolved by hub centric rings.
Old Jun 27, 2007 | 05:16 PM
Big_Bird's Avatar
^^well mine isnt in my steering wheel, which tells me it's my rear wheels. didnt the shop where you had it done tell you you needed hub rings?
Old Jun 27, 2007 | 05:17 PM
Big_Bird's Avatar
new rear tires should be her tomorrow, it feels so unsafe rolling with these right now. And i cant put my stocker on, because one of them has a nail in it.
Old Jun 28, 2007 | 02:55 AM
ayS's Avatar
ayS
bought the wheels from a vendor here and the tires at discount tires. i just asked around and also, on the net, and they said, maybe i needed hub centric rings. so i gave them a try. looked like it may have done the trick. someone was telling me that sometimes the suspension will make your wheels shake at high speeds. i'm not sure if that's true or not. but it does make sense to some degree.
Old Jul 2, 2007 | 12:55 PM
octagon's Avatar
Feeling like i have been dealing with the same thing as others.
5zigen fnor1c bp
42offset w/ hub rings
after abut a month or two the wheel would seemingly wobble, or "be found with the lip out of round" It would feel like i was riding on a rotation egg. Drivers side left suffered the first symptom, them rear. Replaced both with new 5zigens, and same thing is happening. Put steelies back on and everything is good. The feeling was unsafe, would cause the car to cave in with concern to turns like i had no susp braces at all. On the balencer the wheels would balence out, but on the ground running different story.
Old Jul 2, 2007 | 03:39 PM
ayS's Avatar
ayS
after a drive from L.A. i think some of the vibrations have come back. not so much before i put the hub rings on. i'm wondering what it coule be? what else could it be? i torqued down my wheels last night in case maybe one might be loose. they were all pretty tight except for one slightly. but i fixed that. helped a little. (though all in my head i think)
