Offset question
Old May 2, 2006 | 07:56 PM
Bsbox's Avatar
Default Offset question
I want to get some 15' or 16" Work Emotion wheels for my xb. I believe they come with a +44 offset. Will this fit? I think i can get a custom offset but if not will i need spacers? If the stock size has a 38 offset and comes really close (LIKE A FINGER WIDTH) to the suspension arm will a 44 rub? Someone please enlighten me.
Old May 2, 2006 | 10:46 PM
RTon20s's Avatar
Those should fit just fine. They may be a little close in the back to your suspension, but you can always push them out a bit with OTG shims.
Old May 3, 2006 | 12:16 AM
RaginCajun's Avatar
I have 42mm ofset but with 18s. I cant get my pinky between the nub on the suspension and the tire. You should definately order some spacers.
Old May 3, 2006 | 12:20 AM
Bsbox's Avatar
Yeah, that's what i'm sayin. In the back my stock size wheels are really close and they are (i think) +38. So i was afraid a 44 would rub. I have a set of OTG shims i haven't put on yet. Ok so with the shims they would probably be about the same distance from the suspension as my stock wheels? So would the 44 be really close to the fender with shims installed? I've seen smokyxb had those Works and has shims so i know the set up fits, I'm just worried about them being so close to the suspension arm.
Old May 3, 2006 | 01:35 AM
JDMJim's Avatar
why not oreder them in the correct offset? Works can be ordered in two faces designs. Don't be goin out and getting spacers if you don't have to.
Old May 3, 2006 | 01:37 AM
hotbox05's Avatar
yeah a lower offset wheel will look better too.
Old May 3, 2006 | 01:59 AM
Bsbox's Avatar
Ok so what would the "correct" offset be? I was going to put my OTG shims on anyway to get the tires away from the suspension arm and to make the stock wheels more flush with the rear fender. More specific suggestions would be helpful.
Old May 3, 2006 | 02:02 AM
Bsbox's Avatar
By "two faces designs" do mean a stagered offset?
Old May 3, 2006 | 02:23 AM
JDMJim's Avatar
there is alittle more to it than just stagger. Depend on the wheel. +38 is stock offset. So why get a wheel, especially from a company that custom builds for that price, That is stock or higher in offset?
Face design is the way the spokes curve into the center of the wheel. Gives it a dished look. Even the 5Zigen FN-01C can be had in different face designs where the spokes are bent out form the hub to the lip more. Start researchin some rims.
Old May 3, 2006 | 02:39 AM
Bsbox's Avatar
Interesting. I know i'm no expert and i appreciate the help. Bare with me. So what you're saying is that the face design affects the offset, right? So if i just order them with a +38 offset the face design will change from the offered +44 offset? The guy i saw who had these rims on his xb said he had a +44 offset with 10mm spacers. These are the rims i'm talking about.....
http://e-wheelz.com/enter.html?targe..._specials.html
Old May 3, 2006 | 03:38 PM
RTon20s's Avatar
The first question you should probably ask is do you know EXACTLY what offset is? Until you know what offset is, know how it is measured and know how different elements of the wheel design work with offset you really are dead in the water.
No one can answer a question about wheel fitment with 100% certainty if the only information they have is offset. And different face designs don't actually affect the offset of the wheel. What they do affect is the LOOK of the wheel based on a given offset.
Two completely different wheels with completely different faces or centers that have the same offset will place the wheel in the exact same position relative to the car. The difference you will see is in how that center interfaces with the hoop. Now with some center designs you can run more or less offset based on how that center interacts with the hoop. Just bare in mind that changing the offset also changes the wheels relative position to the car.
Now I took a quick look at the wheel you are wanting and it looks like a 15x7 with the +44 offset. Work's website also states that other offsets are available. The only way I see this happening is if they do a custom casting. The wheels you are looking at are a one piece cast wheel. I'm not saying they can't do it by any means. I'm just saying that it will probably be very expensive to have done unless they have already developed a mold for the exact wheel spec you want.
Old May 3, 2006 | 08:12 PM
Dressed2Kill's Avatar
My volks are 17x7 with a 44 offset. They fit fine but i am going to be putting some spacers on to make them look more flush.
Old May 3, 2006 | 09:33 PM
Bsbox's Avatar
Thanks Killa. Are you gonna do OTG's? I need a lift. Does JK have one? Would they do the install for me?
Old May 3, 2006 | 10:18 PM
Bsbox's Avatar
Now the only question is gunmetal or bronze. I've seen both on TCM xb's and i like both, but i can't decide.
Old May 3, 2006 | 11:48 PM
Jk has a lift. I would go bronze, but then again its all about what your tring to do. If you want the wheels to blend in with your TCM get the gunmetal. If you want your wheels to get noticed get the bronze.
Old May 3, 2006 | 11:55 PM
Bsbox's Avatar
Yeah, i was leaning towards bronze. I have wanted some for a while. What about your spacers?
Old May 4, 2006 | 01:55 AM
I have not bought spacers yet because at the moment i am short on $$$. I think i will be getting studed spacers because i want to run a 15mm in the front and a 25mm in the rear.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
