rim and tire problem
Old Jul 20, 2008 | 07:41 PM
e246's Avatar
Default rim and tire problem
well i just recently had lowering springs put on my car.. then the day after i had my kdw 2 tires mounted and balanced on my 18 inch rims.. They said the rims were slightly worped and said on the machine when they spun it it had a little bit of up and down play to it.. I mean it rides good and all but at like 75-90 the steering wheel will slightly shake and when hard braking itll shake too.. It also pulls to the right just slightly.. So is there anyhing wrong and can i fix it cus ive had the rims for a while just wasnt with my car so now i cant try for a refund.. I mean to the eye they dont look bent at all.. What yall think.. and also the tires call for 50psi but can i run 35-40 like usual for the better traction and grip?? thanks
Old Jul 21, 2008 | 03:56 AM
Sciond's Avatar
sounds like out of balance
Old Jul 23, 2008 | 02:41 PM
Leo_EdgeRacing's Avatar
I would take it to a Hunter GSP9700 roadforce balancing machine. It will tell you if the wheel is out of round or if the tire is. You can find one local to you by going to www.gsp9700.com.
Old Jul 25, 2008 | 02:25 PM
bB2NER's Avatar
Music City Scions
Good suggestion. Are you also running hubcentric rings with those rims? If not that may help some with the unwanted vibes. Good luck.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
Hardhitten
19
Nov 23, 2003 07:31 AM
Hardhitten
22
Nov 13, 2003 11:53 PM
WhiteToaster
Oct 12, 2003 06:43 PM
royder1976
Oct 6, 2003 07:41 PM
