Shims vs. Wheel Spacers?
Looked around could find any versus info. So here is my dilema...
I have 17x7 wheels wrapped in 215/45/17 rubber, that i want to make flush (in the rear) with the body. Im thinking 15mm will do the trick, just wandering if i should go with shims or wheel spacers?
Thanks
Thanks
I used the shims from onetongarage.com and they seemed to work really well. the install was a sinch and the overall appearance made the car look better. the shims did not push the rear wheels all the way out but did match them a little closer to the front.
OTG hub spacers are the way to go. you can get them in sizes from 5mm to larger then 30mm. ive noticed different people sell different sizes. you could also have a machine shop make them for you.
im still waiting on my 15mm OTGs i got from another Scionlife member that sells them, BEWARE i paid for them on july 25th, i have recived nothing and he will not respond to any of my emails ( ive tried several emails threw several channels ). i filled a paypal complaint Aug 11th. it makes me so mad when people take your money and run like the internet is en anonymous playground.
Ditto.
Every regular wheel spacer that fits on the outside of your hub creates undue stress on your wheel bearings.
The OTG hub spacers negate that effect by spacing the entire assembly outward from behind the hub. Clever design, and good stuff.
Originally Posted by hotlava1886
niether !!! very unsafe !!
I've been running on 10mm OTG shims for over a year now, and I've got no problems whatsoever. I think hub shims are the way to go, within reason. Anything over 25mm, and I'd say you're nuts.
i agree that wheel spacers are not to safe ......infact it was SOP at a shop i worked at that we would refuse to do wheel & tire work on something that had wheel spacers. "GET IT OUT OF THE SHOP...NOW!!!" we have just seen to much go wrong.
but.... hub spacers.
i don't see anything wrong with them. ive never heard anything bad about them.
it all depends on what type of look you are going for.
if you want to just look the same as the front, i wouldn't use anything more than a 10mm with the 7" wide and a 40mm offset.
i have 7" rims but my offset is onlt 38 so im using 15mm hub spacers. i think ( hoping ) it will push my back tires out just a tad more then front. but i do know it will atleast be the same as front.
if you want to get a little crazy go with a 20mm and show some tread.
I'm running 17x7 et 42 with 215/45 rubber with 20mm otg stacked shims in the rear. I had to roll the passenger side fender, and twerk the parking cable a bit, but all in all I am happy with the result. I agree with the 15mm on 40 et, you may get away with that without having to roll the fender.
Pic
Pic
