Tires keep popping!
I have had my Scion xB for less than a year and have popped my tires 6 times so far. I don't feel like I've been hitting curbs or anything, but I can't think of another explanation for the tires popping this often.
What wheel/tire sizes would be best to keep my tires from popping so easily?
Pictures of xB:
[/url]
Pictures of xB:
[/url]
what do you mean by popping? does the tread literally come off the steel threads? a hole suddenly appears?
give more specific info..... what type of wheel are you using.... whose installing your wheels. tire sizes and wheel widths.
Wheels: 17x7 Team Dynamics wheels Pro Race I
Tires: Mirada-sport gtx
205/40R17 84V is what it says on the tire.
They either have punctures on the outsides or the inside of the tire completely rips. I don't think I've hit many curbs, but even if I have, there must be a better sized rim and tire to take bumps like that.
If the tires are shredding and you're getting holes in the sidewall, those are some crappy tires. Shredding/ripping usually happens because the treads weren't affixed to the belts/ply correctly.
I googled around a bit, and it sounds like those Mirada's are made by some company called TBC that buys old tire molds off major manufacturer's then re-uses them.
In short: Buy another brand and save yourself the headaches
Thanks for the info. Is the size of the tires that i have now be a factor to them popping easily? They are so thin that it seems like it takes nothing for them to rip.
The tires were cheap because i havent had money to change them all out and figuring that they pop so easily, i didnt want to waste the money.
Just took out a loan for $1500 so it should allow me to buy higher-quality tires. someone recommended 215/50/17?
Like guy above suggested, just get some kumho's. I've had good luck w/ falken's too.
Originally Posted by bbszero
I think it's cause of all that wheel gap!
sorry, had to go there.
I would definitely get a little bit bigger tire. 215/45 or the 215/50 that someone already suggested. It will help kill that wheel gap a bit.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
mischadoll
Mar 9, 2015 05:48 AM
cid_mcdp
Jan 5, 2015 02:45 PM
