DIY: xB Sidemarker Modification
Whats up peps. This write up is a how to for keeping your front side markers on when your corner bulbs are on. The side markers will also blink when the corner light blink aswell.
Its not that difficult to do and should not take more than 1hour. Here we go. First off you need to find your side marker. :P https://i53.photobucket.com/albums/g...2/IMG_1434.jpg Once you have done that you need to pop it off. https://i53.photobucket.com/albums/g...2/IMG_1436.jpg To do that you need to push it foward then out. https://i53.photobucket.com/albums/g...2/IMG_1437.jpg Now that you have it out you need to cut open the wire loom. https://i53.photobucket.com/albums/g...2/IMG_1439.jpg Then it is time to cut the white wire. https://i53.photobucket.com/albums/g...2/IMG_1443.jpg Splice open the end that is connected to the light. https://i53.photobucket.com/albums/g...2/IMG_1468.jpg Now get about a 3 foot piece of wire and use a butt connector and connect it to the white wire that you spliced open and to the 3 foot piece of wire. https://i53.photobucket.com/albums/g...2/IMG_1469.jpg Close up the loom using electical tape leaving the 3foot wire out. https://i53.photobucket.com/albums/g...2/IMG_1470.jpg Now you are going to need a metal hanger. https://i53.photobucket.com/albums/g...2/IMG_1461.jpg Open up the hanger as stright as you can. https://i53.photobucket.com/albums/g...2/IMG_1462.jpg You are going to use the hanger so you can fish the wire to the engine bay. https://i53.photobucket.com/albums/g...2/IMG_1463.jpg The hanger should look like this when you get it throught to the side marker opening. https://i53.photobucket.com/albums/g...2/IMG_1464.jpg You are going to wrap electrical tape around the open end of the 3foot wire you have to the hanger like this. https://i53.photobucket.com/albums/g...2/IMG_1465.jpg Then pull the hanger through to the engine bay. https://i53.photobucket.com/albums/g...2/IMG_1466.jpg On your headlight pop out your corner bulb and harnes. https://i53.photobucket.com/albums/g...2/IMG_1444.jpg Take out your bulb so that it dose not get broken your damaged. https://i53.photobucket.com/albums/g...2/IMG_1453.jpg Cut open the loom that is holding the wires together. https://i53.photobucket.com/albums/g...2/IMG_1446.jpg Locate the green wire with the orange stripe and splice it open. https://i53.photobucket.com/albums/g...2/IMG_1450.jpg Connect the end of the wire that you pulled through to the green and orange wire. https://i53.photobucket.com/albums/g...2/IMG_1455.jpg It should look like this. https://i53.photobucket.com/albums/g...2/IMG_1456.jpg Wrap the wires in electrical tape so they will not get lose or damaged. https://i53.photobucket.com/albums/g...2/IMG_1457.jpg Then connet your bulb back your your harness and put it back into the headlight and your done with the one side. Now do the exact same thing to the other side to finish up. We also added chrome bulbs to the cleared headlight. https://i53.photobucket.com/albums/g...2/IMG_1473.jpg Here is the end result, the light is now on with the corner bubls. :eyebrow: https://i53.photobucket.com/albums/g...2/IMG_1472.jpg https://i53.photobucket.com/albums/g...2/IMG_1471.jpg I hope you like it, good luck. |
Hmm... nice mod. Not sure how practical it is though... I'd imagine they still flash right?
i've got mine done like this. nice write up big.
Nice info!
Thx John DON'T START! :silly: |
Don't worry.
I Won't. (Sorry, I couldn't help myself!) |
^ :silly: Its all good! :bow:
John |
Don't matter what anyone else says, I think it's a great write-up! Even better with the great pics!
What's kinda cool is that if the parking lights aren't on, the side markers flash in sync with the front and rear. If they are on, they flash opposite of the front and rear.
Only because I've had problems with butt connectors coming apart due to car vibration and whatnot, I would highly reccomend soldering and heatshrinks for this type of work.
Just my $0.02. |
Good write up but I would suggest using tee taps to tap int the wires. A little more secure that way. Because electrical tape comes off after a while.
Just a suggestion. |
Wow! seems small but its something I love. I have all the parts and the time. Nice dude.
just be careful guys as this is illegal in some states.
duely noted, gracias.
like CA? |
like CA? I'm just assuming it is illegal in a few other states as well. Front sidemarkers are legal in amber , but they can only blink with the blinkers they cannot be like a running light. as to why? ya got me. front signals can be white or amber , rear signals can be red or amber. so there ya guys go :) |
like CA? I'm just assuming it is illegal in a few other states as well. Front sidemarkers are legal in amber , but they can only blink with the blinkers they cannot be like a running light. as to why? ya got me. front signals can be white or amber , rear signals can be red or amber. so there ya guys go :) Figured as much. CA sucks we cant do anything to our cars without it beind illegal. |
