headlight install
i searched but i couldnt find it!
does ne1 have any detailed pics of how to put in new headlights and if i can get pics of spliced halo lights (with led preferably)!!!!!!
To pull out the whole headlight bucket you need to pull off the bumper skin. Thats done with a row of bolts along the inside of each wheelwell. There are also boltes under the upper grille and I'm sure there are bolts behind the removable end pieces in the lover grille.
Once you remove all those bolts the bumper cover should slide off. Then the headlights are easy.
Yeah bumper has to come off. There should be two bolts in each wheel well and then there are two or three underneath the top grill. With a little tugging the top of the bumper will come off. Dont bother taking all the bolts and clips off the bottom "fingers" behind the lower lip. You can just pull the top out and have access to everything you need while leaving the bumper partially attached... Good luck!
I can get my bumper off in under 5 minutes since its been off so many times.
missing_image
Feb 7, 2015 07:18 PM
minter66
Dec 15, 2014 01:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
