makeing windshiled squirters flash with alarm
What would I need to attach to the alarm indicator wiring in my xb, that would make my (soon to get)lighted windshield squirters flash(at the same time it flashes) when my alarm is on? I have seen it done on other cars just wondering how to do it.
I just like lighted things, and I would never have them on when driving only when parked and used as alarm indicator lights, other wise you really can't tell the difference when they are not on except they are clear.
Fair enough... I would think if you tap into the turn signal wire, that would do it. Although they would also flash when you turned your indicator on while driving. If you wired them to a switch, that would allow you to turn them off while driving... I dunno. To me, it sounds like more trouble than it's worth.
yeah I was thinking there is some kind of switch that you could hook up to the alarm wire that would sense when there is current going through it and switch the squirter lights on and off. I guess I should go to a electronics store, maybe they would know
All you have to do is tap the wires into the LED for the alarm that is mounted on the dash,I have seen it done with mirror marker lights really draws your attension when it is dark out.
Scott
Scott
Scott
Scott
wouldn't drawing power from that little LED be to much for the circuit?
Originally Posted by burstaneurysm
No. The draw from two LEDs is barely noticeable.
Originally Posted by spr0k3t
Looks like it's time to wire up a relay to make sure you don't fry it.
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
