need help on side mirror removal
Originally Posted by TheScionicMan
There should be a couple of screws underneath, and in the door. I'm not sure which ones you have already done.
any body knows how to take off the door panels?
thanks,
sid
nevermind, that freaken harness is inside the door panel. door panel has 2 screws and i pop screw out side. after taking that off, i began to pull the panel from the bottom first then lift up.
thanks,
sid
thanks,
sid
That's an easy one. Theres a screw in the door handle and the pull handle and a faky screw tab thing near the front edge of the door panel. Remove those, grab the bottom of the door panel and pull outward. It has several plastic clips that hold it on. They slip into the brackets, not like the old ones that were glued on and would break off.
Pull the panel outward. Unhook the wiring and lift the panel over the locking rod.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
mischadoll
Mar 9, 2015 05:48 AM
