noob needing help I think I damaged my clearcoat
I messed up my paint
I debaged using dental floss after the car was sitting in a hundred degree sun. I purchased some bug tar remover that was safe for auto finishes. Used a little elbow grease and noticed fine swirl scratches and what appears to be a loss of the clearcoat where the emblems are. Do I have to take it in to dealer or can I still fix it with a clay bar and some wax
I will post pics soon to show you the damage
clay bar may but i doubt it. use a precleaner wax. if that dont work, use a swirl/scratch remover then wax. if all else fails, take it to a professional detail shop or your dealer to have it buffed out.
go to an auto body supply store and buy a bottle of finess-it. its a mild abrasive polish that should take out any fine swirl/scratches from the clear. make sure you use 100% cotton or a synthetic towel to rub the marks out. but like badbasic said.. you might need to employ the help of a bodyshop if they are bad to buff out. most good shops would probly take care of it for nothing if they just need to drag the buffer over it on or two times.
rancur3p1c
Dec 19, 2014 04:30 PM
