Problems with re-sealing
Old Feb 22, 2008 | 03:58 AM
xBbeatBox's Avatar
Default Problems with re-sealing
I use the bake-it method to reseal my foglights. So far so good, but some how I got some of the silicone on my lense! I'm not sure how to get it off. I tried to use a product called 'lift off' which really sucks. Instead of taking the silicone off, it just spread it over a wider area making it look horrible. Some others told me to use denatured alcohol.
Anyone else had this problem? How did you fix it! Any help is appreciated fellas
Old Feb 22, 2008 | 05:38 AM
IH8ONYU's Avatar
get the strongest solvent you can stand to smell... it'll come off with a little elbow grease.
Old Feb 22, 2008 | 10:25 AM
daneisthegreatest's Avatar
diesel gas, if you can get a little bit of that on a rag and rub it, the silicone will come right off
Old Feb 22, 2008 | 04:51 PM
xBbeatBox's Avatar
what kind of solvent would you suggest? Denatured alcohol turperntine?
Old Feb 22, 2008 | 08:30 PM
IH8ONYU's Avatar
diesil gas, starter fluid, brakeclean, etc...
denatured alc may not be strong enough, trupentine may do it... start with what you have handy... if a couple rubs doesn't start to take it off, go with something stronger..
Old Feb 23, 2008 | 03:41 AM
xBbeatBox's Avatar
Anything I should stay away from that might mess up the lense?
Old Feb 24, 2008 | 02:16 AM
da_bodyman's Avatar
stay away from paint thinner
Old Feb 24, 2008 | 01:02 PM
DarkTari's Avatar
You should be able to take a razor blade to it. Otherwise Goof-Off or Goo-Gone will work, you just have to you a clean rag continuously.
Old Feb 24, 2008 | 10:01 PM
xBbeatBox's Avatar
Googone doesn't even touch it. I tried Power Steering fluid that actually worked pretty well. Thanks for all the info guyus
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
Moth
Apr 14, 2015 12:17 AM
