remove rear wiper
What are you talkin ' about...remove your what???
j/k
In a word, PULL. You can even get over cautious and get a steering whell puller if you are nervous, but I just pulled mine off.
OR
You can look in the tech section.....most DIY's are alread covered.
OR
You could use the search button......
j/k
OR
OR
j/k
OR
OR
j/k
OR
OR
I know the search button, I have been a part of scion life longer than most, usually in the tech section they would have this covered, but its not. So I would guess if the mods of scionlife saw a good tech thread on doing this they would add it to the tech sections which its not, the only one in there is how to make it stick straight up. But nothing about how to get the thing off. Thanks to all that responded ,I thought that was probably the answer(just yanking on it) but I just did not want to pust something or bend the hatch, yanking it out.
You gotta go behind the hatch and get it from the other side, just popping off the cap and unscrewing the bolt isnt gonna get it off...
Here: https://www.scionlife.com/forums/viewtopic.php?t=99618
That gives you the basic idea of what to do.
Originally Posted by hayalex6
pop off the cap, undo the 10mm nut, PULL OFF THE WIPER.
This should take you 15 seconds.
kleecker
Jan 9, 2015 02:26 PM
