Removing Embelms
So we took my rear scion, xB embels off today and they glue is ON THERE!! I have tried rubbing alcohol, goo gone and it has removed it but hardly anything else out there that would work great?????? HELP!!
Da Mac wrote:
F that, that bug n tar remover by meguiuars left white residue over my grill and it left dull white(greyish) mess on my SW. I don't know what to do with it now. Was going to buy a clay bar.... but I saw it was by meguiars so I put it down......
get a can of 3m bug and tar remover thats what I used and it can off real easy. You should be able to get it at a local auto parts store..
Must have been cold there!
Hotter it is, more adhesive comes off with the emblem. It was over 85 deg SoCal heat when mine came off. I used WD-40 on a soft cotton rag to remove the residue. It cuts road tar and emblem adhesive.
Disclaimer: Try it on a non conspicuous place first, YMMV. It did OK, mines PW.
i did mine at nite in about 40* w/ a hair dryer and floss, i removed the emblem ok, but left all the glue on as well. i got some all purpose solvent from work from the detail guys. w/ some heat it came off pretty good w/ a lil ghosting. immediatly follow w/ wax. the ghostin went away after a few washings and some more waxin that area.
the solvent also worked extremely well on window tint glue in conjuntion w/ a razor blade. it took me a total for 1 hour to remove the film and glue on both from windows
Originally Posted by Max
Just wax the hatch if time is a problem.
and i have heard if u hold heat directly on a spot for too long, u will bubble ur paint...i just moved the hair dryer side to side and had no problems
i used this real cheap sponge i got from pep boys, in a towel pack
ithas a mesh around the sponge,
rubbed, a little elbow grease, came right off, then i just re-waxed the area and now its clean,
wouldnt think something so cheap would do such a good job
Originally Posted by Cmec2004
Its like onl 40 degress here does that matter
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
steeze69
May 24, 2021 02:57 AM
