Roof mount antenna
Roof mount antenna
I installed a roof mount antenna to replace the weak window antenna. i got it from installer.com it's a amplified antennaworks stock VW antenna. I drilled a hole in the center ridge near the back and connected to the stock antenna wire where it connects to the distribution block. This wiring has both antenna coax and 12volt power wire. A xA antenna or Corolla antenna will work as well but I wanted a amplified antenna and it works really well.
hmm. i've never had a problem with bad reception and I sure as hell wouldn;t add a monstrosity like that to my car. hmm...
are you trying to capture radio stations from more than 50 miles away ?
I know I personally hardly even use the radio. i-pod ftw.
the lil whip antenna's look cool on very small cars. oldschool vw rabbit , new vw beetle , things like that. yaris hatch. but on 4 doors or larger compacts not too good. imo.
pjl52
08-13-2015 02:38 PM
