Running boards? Scion xB 2006
Old Feb 22, 2006 | 11:01 PM
TRDBox's Avatar
i hear ya lol
thats a nifty lil stool
still if you lower it i think that would do best
same wear on tires and about same ride
i see you do some traveling
if your ever in va beach look me up and if you havent lowered it ill put em on for free
i got the bags on it now and had the TRD springs before
Old Feb 22, 2006 | 11:18 PM
fasteddy's Avatar
Originally Posted by TRDBox
i hear ya lol
Thank you,,,Guess I may as well forget the idea of running boards!
I am sorts shy on the lowering aspect tho. It sits pretty low to the ground as it is.
Think I will stay with that fancy handy-dandy one of a kind $12.00 stool, pain as it may be.
LOL! Thanks guys,,,eddy
Old Feb 23, 2006 | 04:15 AM
Max2k's Avatar
You could take the side skirt off and bolt something up; it wouldn't be that hard for a shop to do for you.
Old Feb 23, 2006 | 04:38 AM
UBOW's Avatar
Running boards are not out of the question. Any good van conversion shop can do the fab for you. They could take existing boards and cut them to length, remove the lower body moulding and weld on the new boards. Shouldn't be any trick to it at all.
Old Feb 27, 2006 | 03:48 AM
XB_XIII's Avatar
bag ur xb out, then u can slam that ____ to the ground.... better than sum ugly running boards........ or invest into a mini van........... good luck with whatever you decide to do
Old Feb 27, 2006 | 08:14 PM
grizzly_choppers's Avatar
That Max2k ain't no dummy!
This is exactly what I have been thinking while reading this thread. Check out the Toyota 4Runner running boards or possibly some universal fit ones. Any trailer hitch or truck accessory shop in your area should be able to set something up for you.
Good luck!
-Alex
Old Feb 27, 2006 | 08:44 PM
Sid_xBicious's Avatar
haven't seen the skirt off, but i'm pretty sure the holes will not support 100 lbs weight to be used on running boards. But yeah theres a lot of possibility, its just a matter of fabricating the right brace that will bolt on the right hole where ever that may be.
Old Feb 27, 2006 | 08:57 PM
archangel's Avatar
eddy
Airbags. Seems like the best solution. They keep the car at a normal ride hieght, then you deflate them and the whole car will drop to the ground. Making it easy to get in. Once your wife is in. You just flipa a switch and it will come back up to normal ride height. Though the only thing is it may kinda pop back up. I am sure there is a way to bring it up slow.
Old Feb 27, 2006 | 08:59 PM
ogerdgonz's Avatar
look into auto steps for an rv or lifted trucks. They come out when the door is opened. The shop could modify the mount causing it to drop down and out .
fur_pig
Mar 20, 2020 04:28 PM
fur_pig
Scion tC 1G Wheel & Tire
Jan 14, 2019 12:03 AM
cid_mcdp
Jan 5, 2015 02:45 PM
TRDSCIONTC06
Dec 31, 2014 10:12 PM
Kiwibox
Dec 15, 2014 09:46 PM
