Running Wires through Firewall Help
I am currently installing a underbody kit and am having problems finding a place to get the wire for the front tube into the cabin of the car. i am using ozniums flowlight single color kit. I would like to not have to drill a hole through the firewall at all costs. if anybody could help i would greatly appriciate it. thanks
Just look for the harness already running thru. There are two of them, one on drivers side, one on passengers side. poke a hole from engine compartment into passenger cabin, if you use a coat hanger, pass it thru, make a loop in the end, tie a sting or wire, pull it thru,tie your wires to the string/coat hanger, and pull it back thru.
locate the grommet on the firewall (battery side)
tape the wire the the end of a dull flathead (see the red handle?) and push it thru. this picture was taken looking up the dash from the clutch pedal
hoping this picture explains where you are looking in the last photo
find the end of the screwdriver you pushed thru, and remove the tape (it's red)
pull the wire thru, then go back around and remove the push tool
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
randode
44
06-29-2004 04:19 PM
