Why is this happening?!!!
Old Feb 29, 2008 | 06:58 AM
driveonfishboy's Avatar
Default Why is this happening?!!!
I have been having problems with the LED lights above the license plate. I don't remember what brand they were and I bought a bunch of them all at once. They have several LEDs on one bulb and look like a long bulb with a lot of bumps on it. I don't think the problem is with the bulb. I keep burning the LEDs out but only on the driver's side. I just burned out my last one and this makes 4! What's going on? The passenger side is fine. Is this just bad luck, 'cause I don't think so. What happens is that the LEDs flicker and then burn out one by one. I slowly gets darker and darker until all of them are gone. I haven't lost a single LED on the passenger side.
Old Feb 29, 2008 | 10:15 AM
hwybox's Avatar
what power source are you running to the LEDs, I believe they run on different voltage than regular lights. am I wrong?
Old Feb 29, 2008 | 01:15 PM
swartzautoman's Avatar
you are puting too muck voltage to them.
"slowly gets darker and darker until all of them are gone" thing is what maks me think so, i tried it one time just to see what would happen.
i took a regular 10mm LED with no resister and touched it to a 9 volt battery and thats just what it did, darker and darker untill it went out with a small pop noise.
Old Feb 29, 2008 | 03:39 PM
IH8ONYU's Avatar
you need only to get the correct resistors to match up to 12v.. i would get them on both left and right sides, just to be safe. if you go to radio shack, they can get you what you need easily..
Old Mar 1, 2008 | 04:32 AM
Thanks for the replys. I have them just plugged into the license plate receptical. They are supposed to plug right in with no mods. I talked to someone today that may have a clue. I told him that the bulbs never did fit in snug. They fit in kinda loosely but not enough to go off and on. He said that the connection might not be real good causing "micro-arcing", shorting out the lights. Is that true?
Old Mar 1, 2008 | 02:52 PM
Black_Sheep_xB's Avatar
"He said that the connection might not be real good causing "micro-arcing", shorting out the lights. Is that true?"
Nothing is impossible, but that would be easily corrected,
dielectric grease the contacts. I would do what IH8ONU said, install a resistor on the power line.. OZNIUM.com
Old Mar 2, 2008 | 11:50 PM
Thanks. I'm thinking it's the arcing. Remember that the other side has no problems whatsoever. Does the dielectric grease keep it from arcing?
Old Mar 3, 2008 | 12:59 AM
yep
Old Mar 3, 2008 | 02:37 AM
Thanks for all the help. I'm going to do the grease and add the resistor so I don't have to screw with it again! ( I HOPE )
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
HATEnFATE
Regional - Plains
Jul 29, 2015 05:53 PM
