xB 2005 Tail Lights..
Old Aug 29, 2021 | 04:04 PM
mbernard356's Avatar
Default xB 2005 Tail Lights..
When I turn off my xB, the brake pedal stop lights (Tail) on both sides remain on.
Is like is the brake pedal remains pressed. I removed both bulbs until I get a solution.
kindly request info of possible causes.
Many thanks!
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Aug 29, 2021 at 07:43 PM. Reason: Moved to Correct Forum by Administrator
Old Aug 30, 2021 | 10:50 AM
2stroked's Avatar
Many thanks!
First of all, do not drive the car as you no longer have functioning brake lights.
Second, check the switch on your brake pedal that actuates the brake lights. It's most likely failed. Easy fix.
BTW, Does your CHMSL (center high mount stop light) work normally?
__________________
Old Aug 30, 2021 | 03:37 PM
DannoXYZ's Avatar
Moderator
Moderator
yup, failed brake light switch. perhaps not.
Look around on floor for rubber bumper that presses on brake-light switch. If this piece falls off, brake-light switch won't be pressed when pedal is up. Thus switch won't turn off brake-light like normal.
mbernard356
Aug 23, 2021 11:31 PM
nnnickkk
Oct 29, 2007 11:43 PM
schwettynuts
May 31, 2005 06:34 AM
lykemlo
Dec 27, 2004 05:33 PM
velocitybb
Jun 29, 2004 07:11 PM
