Adding a remote start/security
Old Sep 4, 2013 | 08:13 PM
supertech06's Avatar
Default Adding a remote start/security
looking at the wiring diagram and i cant seem to make sense of it, im new to installing stuff on my own but im pretty good with electronics, here is what i have
main harness, 6pin
(+)12VDC constant input - white/blue (ignition switch harness)
(-)chassis ground - assume this just mounts to the car
(-)200mA horn hon output - ???
light flash isolation wire(pin 87a light flash relay)- ???
pin 30 of light flash relay -???
500mA ground when armed output - ???
remote start, 8-pin
(+)ignition 1 input/output - Black/red (ignition switch harness)
(+)12VDC constant input for ignition and flex relays - ???
(+)accessory output - blue/red
(+)starter output - black
(+)12VDC input for inition 1 relay - ???
(+)ignition2/flex relay output - black/yellow
(+) flex relay inout 87a keyside(if required) of flex relay -????
(+)12VDC contant input for acc stater relays -???
door lock 3-pin
500mA (-) unlock output - yellow/black
empty
500mA (-) lock output - blue/white
aux/shutdown harness 24-pin
(-)200mA flex relay control output - ???
(-)neutral safety input - ???
(-)200mA 2nd status/rear defogger output - ???
(-)200mA Factory alarm disarm output - n/a
(-)200mA trunk release output - brown/yellow
(-)door input - ???
(-)200mA dome light output - ???
empty
(-)200mA status ouput - ????
(-)200mA ignition 1 output - ???
(-)200mA aux 3 output - n/a
(+)door input
(-)200mA aux 1 output - n/a
(-)200mA aux 2 output - n/a
(-)200mA aux 4 output - n/a
(+)brake shutdown - ????
(-)hood pin input - ??
(-)200mA starter output -???
factory horn input(use jumper to set polarity) -???
empty
activation input - ???
(-)200mA accessory output
tachometer input - black (pin 9 OBDII)
(-)200mA factory alarm output -???
not concerned with the extra aux outputs since i wont use them.
what i need is confirmation that these are the right wires and what are the ones im missing with the ??? or if they are needed.
thanks
Old Sep 10, 2013 | 04:26 AM
EquisBe's Avatar
http://www.bulldogsecurity.com/bdnew...gdiagrams.aspx you can go to bulldogsecurity.com its very helpful you can look up wiring.
Old Sep 10, 2013 | 04:31 AM
EquisBe's Avatar
The neutral safety input has to be grounded otherwise remote start wont turn on, brake shutdown goes to your brake lamp switch + , otherwise remote start wont know to shutdown after youve shifted out of park, youll need a hoodpin for safety reasons, you dont want remote starting by accident when youre under hood.
Old Sep 10, 2013 | 04:35 AM
EquisBe's Avatar
Im assuming youre installing a DEI remote start from the description, youll need to hook up any 12v+ inputs in order for the IGN /ACC outputs to work.
BlingSlade
Nov 20, 2015 06:56 PM
neneago
Oct 27, 2015 04:47 PM
Denzel
Oct 14, 2015 10:15 PM
SJMiller
Sep 12, 2015 06:33 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
