Anyone make stiffer motor mounts/motor mount bushings?
Old Feb 12, 2004 | 07:32 PM
jackmott's Avatar
Default Anyone make stiffer motor mounts/motor mount bushings?
I've seen this mod greatly reduce wheel hop in other front wheel drive cars.
Old Feb 12, 2004 | 07:39 PM
dinkjs's Avatar
I dont think so....but go check out enery suspensions website......
But my personal opinion I feel heavy duty motor mounts are a waste of time unless your making enough power were wheel hop becomes a problem very frequently....for these cars I feel they arent worth the time.....maybe for the tC though
Old Feb 12, 2004 | 07:41 PM
jackmott's Avatar
I thought so too, but I was getting wheel hop all over the place since I got my scion, of courses, its been raining out. But yeah, first gear is so agressive it can spin those lil tires.
But its such a cheap mod (usually) and easy to install with nearly no downside except a little noise.
Old Feb 12, 2004 | 08:00 PM
TheRedBox's Avatar
yenno you can do it the cheap way and insert polyethelene (plastic cutting board) in the motor mounts. A lot of DSM guys do this. Or you can add a layer or window weld, widow weld.. dont remember what its called, on top of the mounts. That way takes longer, but it helps just as much.
Old Feb 12, 2004 | 09:21 PM
dinkjs's Avatar
Sorry I own a DSM.....and I am a frequent person on my cars website and I have never heard of using plastic cutting board....nor anyone else used it
Old Feb 12, 2004 | 10:05 PM
TheRedBox's Avatar
YOU NEVER HEARD OF THAT AND YOU OWN A DSM????? DUDE WHERE HAVE YOU BEEN??? YOU NEVER USED THE VFAQ?!?!?! You are not a DSMer if you dont use the VFAQ.
http://vfaq.com/index-main.html
under engines, scroll to the bottom.
OR heres a direct link
http://www.geocities.com/gulfblvd/mountinserts.htm
I don't know if I should give you a :oops: , a , a , a :? , or a for being a DSMers that didn't know that.
Old Feb 12, 2004 | 11:22 PM
dinkjs's Avatar
just because its on there doesnt mean people do it
Old Feb 12, 2004 | 11:25 PM
TheRedBox's Avatar
There's a whole bunch of stuff on there, from turbo swap guides, to clutch jobs even wiring up your SAFC....
Old Feb 13, 2004 | 12:02 AM
HemanC's Avatar
I've seen Weapon-R has something like this one. Contact Leo for a more accurate info
Old Feb 13, 2004 | 12:10 AM
abbfanuc's Avatar
I saw a prototype of weapon-r. Scionmag had one at Exposed with a new double tube intake.
Old Feb 13, 2004 | 12:44 AM
scionxb04's Avatar
i have the engery suspension engine mounts in my 2k civic si...along with allota of other people i know who drag at sac speedway....either u gotta use the inserts or get real mounts.....the inserts helped with launch hookup immensly.....if u can find the mount inserts for the scion let me know where.....
Old Feb 15, 2004 | 06:40 AM
Guest
Guest
Posts: n/a
I will check the mounts to see if they are the same as a corolla. Sometimes toyota uses the same design to save money and I think I saw the inserts for a corolla on scion tuner magazine. :D
Old Feb 16, 2004 | 07:18 AM
scionxb04's Avatar
let me know what u find....
XirtaXa
24
Jan 14, 2025 03:49 PM
MinusPrevious
15
Dec 12, 2020 06:47 PM
NonStopTuning
Jun 29, 2015 07:42 PM
tc_Jake
Dec 31, 2014 01:45 AM
fluxingnation
Dec 26, 2014 04:28 PM
