The back seats bolt are damn hard to remove
Old May 22, 2005 | 06:11 PM
blueboxerxb's Avatar
Default The back seats bolt are damn hard to remove
Anyone has an idea how to remove them?
i got the middle one but the other 2 on the sides are damn hard to remove. it said size 11 ont he bolt but a size 11 driver wont fit and i took the middle one of by a size 12.
By the way how can i remove the seat belt part?
Old May 22, 2005 | 06:22 PM
pflocal's Avatar
a socket with a ratchet and extension should make removal easier.
Old May 22, 2005 | 06:30 PM
Max2k's Avatar
The middle plastic piece fo the seatbelt pops off to reveal a 14mm bolt.
You're going to want to slip a piece of pipe over your socket wrench to get a bit more leverage to take the seat bolts off.
Also, there are 2 14mm bolts that hold the seats in where they pivot. You have to pull away the seatback cushion.
Old May 22, 2005 | 06:31 PM
thank you for the quick response!!!
i have a ratchet, but where can i find an extension?
Old May 22, 2005 | 06:59 PM
Max2k's Avatar
Just use a pipe over the handle for extra leverage.
Old May 22, 2005 | 07:02 PM
Ok i find out 3 little tools from my dad's tool box
will these work?
Old May 22, 2005 | 07:20 PM
SuperCrunchyAction's Avatar
You need to get a good sized socket wrench so you can put some leverage on those bolts. Use the proper tools and the job is much easier.
Old May 22, 2005 | 08:34 PM
Big_Jim's Avatar
head over to wallyworld and get yourself a 12v impact gun.
its sounds horrible, but it makes stuff like this so much easier.
i used the gun for my grand marquis seats and on the lugs of many cars.
Jim.
Old May 22, 2005 | 09:44 PM
thanks Big_Jim
And how much is that impact gum?
Old May 22, 2005 | 09:52 PM
hotbox05's Avatar
too expensive for a one use job , just man handle them mine came out quite easily and they are 12mm the number 11 that you saw refers to the grade of the bolt aka strength. mine came out quite easily , every car is different , but just use a bit o force and it should come out easily
Old May 22, 2005 | 10:03 PM
Big_Jim's Avatar
the gun was like $20 at walmart.
cant really say it would be a one use thing, keep it with ur spare if you're overcautious of gettin a flat........
Old May 22, 2005 | 10:27 PM
Sublimize23's Avatar
I would stay away from electric impacts... I have a makita 12V one, and it sucks. I have since upgraded my air compressor, so I bought a good 1/2" impact. oh, and the extensions you found in your dad's tool box won't help you get that bolt out, those are meant to extend the actual socket to where you can't fit the ratchet (handle).
Old May 22, 2005 | 10:28 PM
it also helps if you keep constant pressure on the bolt, they come loose that way sometimes.
Old May 22, 2005 | 10:37 PM
BoomBox757's Avatar
DelMarVa
mine came off with a ratchet
lvlisslvlelissa
Scion xD ICE & Interior
Oct 13, 2023 03:40 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
evolving_machine
Jan 13, 2015 08:04 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Roach
Aug 17, 2003 03:06 AM
