Body shop guys, need advice
Old Mar 25, 2007 | 01:51 AM
1epoXyBox's Avatar
Default Body shop guys, need advice
Someone backed up into me. Im lucky, the guy said he is going to pay for it. What is the best way to have this repaired to its original state? Do they usually try to pull the metal out, or do they usually bondo? I just wanted to get some different options before I go to the body shop. Thanks in advance.
Old Mar 25, 2007 | 02:22 AM
salteen's Avatar
I'm sure they can hammer that out and I'm sure a little bondo will be used to smooth it out just right. I have a rock chip on one of my fenders that I still have to get fixed...guh
Old Mar 25, 2007 | 02:47 AM
biff1805's Avatar
CinSity Scions
this topic is perfect for me.....im a body guy in a colision shop....it should be hammered out, smoothed out with bondo, primed, sprayed with color then blended with clear
Old Mar 25, 2007 | 05:02 AM
D_M_A_N's Avatar
If you can get behind that panel to hammer it out, they would do that and then smooth it out with bondoe, primer, then refinished as stated above.
There's no getting around using body filler. Thats just how its done.
If you CANT get behind it to bang it out, then the shop SHOULD tack weld on some pins with a special tool, then slap bar it out, again with a special type of slap bar that clamps onto the pins. after its shaped out decently the pins get cut of and ground down to the metal surface, and then the body filler, etc.
The ghetto way would be to drill a few holes, use a traditional slap bar to screw into the holes and slap out the dent, grind it down smooth, use a couple of types of body filler then refinish it.
(ex-body man, grew up in the biz)
Old Mar 25, 2007 | 08:33 AM
1epoXyBox's Avatar
Thanks for the help guys!!!!!!
Ferretgrrl
Oct 15, 2018 02:50 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
scsteven
Jan 25, 2015 01:06 AM
wesley_t
Dec 18, 2014 06:59 AM
DjFrOsT
Dec 13, 2003 04:18 AM
