Brake light on passenger-side doesn't work. Turn signal is fine.
Old 01-20-2015, 08:07 PM
Scion Dynasty
xBSciontist's Avatar
Default Brake light on passenger-side doesn't work. Turn signal is fine.
I have a 2004 Scion xB. However, my after-market option (dealer installed) passenger side brake light is no longer working properly. I thought it was the bulb that went bad so I replaced it. The brake light doesn't light up when applying the brake, however, the turn signal works fine on the same bulb it utilizes. I checked the two fuses the Tail and Stop fuse and they both look fine. Is there another fuse I need to check to verify if it is bad or not in order to get my passenger side brake light to work? I'm hoping that this is an easy fix that I could perform on my own and not pay an arm and a leg to get this fixed at the dealership. Also, I'm hoping that I don't have to buy a new tail light. Please let me know how I can fix my passenger-side brake light to work again. Thank you for your time.
xBSciontist is offline
Old 12-31-2016, 03:54 PM
ironman3452's Avatar
here is my take on this, first, you said that you replaced the bulb, and it did nothing, does the drivers side come on when you press the brake pedal?, if it does, then it is not a fuse, I would go and buy a test light, that way you can see if there is power at the lamp holder, next I would check all grounds, it is possible that one on that side has come off, look for the simple thing first, try the lamp from the drivers side if it comes on, you have a bad lamp, then just go and buy new ones, hope this helps let me know.
ironman3452 is offline
Old 10-28-2018, 10:42 AM
motorhead99's Avatar
Cool
answer socket is bad....
motorhead99 is offline
Old 10-29-2018, 04:03 PM
RichBinAZ's Avatar
So the turn signal flashes the brake part of the bulb. That says the bulbs are fine and the problem is in the wiring... That will be hard to find - do you have any animals chewing on the wiring?
You also said this was a dealer optional install - did they use a proper kit where they plug the oem harness into the brake light directly or thru a proper plug? Or did they do it with those wire jumpers on top of the original wires?
RichBinAZ is offline
Old 10-29-2018, 08:09 PM
most issues are....well mine was also had rodent around, but I used a test light to check my wires were all good but to find out my socket was a bit old and the contact on the tail light was a bit dirty, so I took it apart cleaned it and get a new socket and now it's all fixed. you have 3 light bulb using a cheap OEM contact plate so it's bound to get old and dirty., better yet get a new tail light with all new contacts.
Old 06-17-2019, 10:58 PM
AbhorrentAngie's Avatar
Hey motorhead99,
Would you mind telling me how you replaced the socket? What part did you purchase?
The contact for the taillamp on one of my TYCs crapped out. I'm hoping to not replace the whole thing & was looking for the wiring harness which has been discontinued - probably because it's a piece - TPS25-52041-wh (I've also seen it listed as PTS25-52041-wh).
I'd appreciate your knowledge!
Thanks,
Angie
AbhorrentAngie is offline
Old 06-18-2019, 03:06 PM
62Fender's Avatar
The metal wire connectors have a locking pin that locks each wire connector into the socket. A special tool disengages the locking pins and you pull out each connector, one at a time. Reassembly doesn't require a tool. You just insert connectors into the (new) socket holes. The locking pins will snap in place. If you don't have the tool, the smallest jewelers screwdriver might fit into the socket hole. If that's too big, you might have to use a medium or large sewing needle.
I couldn't find a socket part number. Have you tried electronic contact cleaner spray? If you try it, first disconnect your negative battery terminal (and make sure to wait for wet spray to completely evaporate before reconnecting the battery.) Temporary liquid build up might cause a short.
62Fender is offline
ktwo
Scion tC 1G ICE & Interior
09-09-2017 04:15 PM
Lengendary
Scion tC 1G Aero & Exterior
9
07-01-2010 06:55 AM
CK028
12-01-2009 01:29 PM
Kvizzel
11-09-2009 06:42 PM
sTIcKyrIce
11-21-2008 02:09 PM
Quick Reply: Brake light on passenger-side doesn't work. Turn signal is fine.
