A/C use and MPG questions XB
Old Oct 21, 2005 | 06:20 PM
Kanotoa's Avatar
Default A/C use and MPG questions XB
My first question how much on average does using the A/C all the time affect gas mileage?
My second question is does turning the A/C all the way up force the A/C compressor to run all the time or is it running all the time anyway? By turning it down (fan or temp) does this make the compressor engage less. This may be a moot point though because I need full A/C on a hot day, I could turn it down on a cool night though.
Old Oct 21, 2005 | 07:29 PM
Yellow_Sub's Avatar
Yeah i'd love to know that info to!
Old Oct 21, 2005 | 07:55 PM
mikem53's Avatar
The compressor cycles on and off when the AC is on. This keep the evaporator from freezing up. A higher fan setting will make the compressor cycles longer to keep up with the higher airflow.
The compressor is very efficient and does not consume much engine power.
Having the window open causes more HP loss from drag than running the AC compressor
Old Oct 21, 2005 | 08:15 PM
joe52985's Avatar
sIcKsCiOnS
mythbusters (best show ever!) did a test on this, the conslusion: On their test cars, ford explorers, below 50 mph, its more efficient to keep the windows open, above 50 windows up, AC on. That doesnt mean it speaks for all vehicle because some compressors are more efficient than others, but its a good general rule.
Old Oct 21, 2005 | 08:37 PM
Newtmaker's Avatar
I'm in Florida- we use AC even in winter!
I have made some trips without AC and the difference in mpg was negligable, maybe 1 mpg.
Walt
Old Oct 21, 2005 | 08:42 PM
PaganGuy's Avatar
I have noticed a big differance in MPG between the 2. If I keep the AC off I can get 32 MPG, with it on for long times it will go down to 25-26. Now the big problem will be the drop due to winter temps, takes longer for engine to warm up.
Old Oct 21, 2005 | 09:12 PM
tvc15_2000's Avatar
Mythbusters TV show did research on windows open vs AC. They found below 45 MPH window open provides better gas mileage. Above 50 AC provides better mileage.
Old Oct 21, 2005 | 09:18 PM
Sparta's Avatar
hey kanotoa i know you from mma.tv hahaha
glad you found this site as well
Old Oct 22, 2005 | 02:03 AM
Kanotoa's Avatar
What's your handle there? Not enough room on MMA.TV to get all my trolling in.
Old Oct 22, 2005 | 02:19 AM
Tomas's Avatar
Admin Emeritus
The compressor in the xB is not a cycling compressor, but a variable displacement compressor. Rather than having a clutch that engages and disengages it is electronicly controlled to change it's displacement.
Check the service manuals...
Last long trip with A/C on all the way both direction got 36MPG on a 300 mile trip.
Old Oct 22, 2005 | 02:35 AM
kewlbox's Avatar
That was the first thing i noticed. Keep the windows up and the air on, and the M.P.G. stayed @ 33 to 34 , open the windows and it droped down to 30 to 31.
Old Oct 22, 2005 | 02:57 AM
Kanotoa's Avatar
Thanxs
Old Oct 22, 2005 | 12:52 PM
BOXCAR's Avatar
I don't notice hardly any difference on or off.
Old Oct 22, 2005 | 02:19 PM
Sciond's Avatar
yep the mythbuster's inf was dead on..I proved it to myself all summer
Old Oct 22, 2005 | 02:45 PM
s10v8's Avatar
when using the a/c do a couple things to save gas, let the engine get to temp before turning a/c on, drive with the windows down to get as much hot air out of the car before turning on the a/c, and i don't turn the a/c on until i get to highway speeds, so i don't accel from a stop with the a/c on, i get on average 35 mpg in my auto xB. the key to getting better mileage, with a/c or without, is not having a heavy foot and keeping the rpm's around or below 3,000
Old Oct 22, 2005 | 06:22 PM
mikee1680's Avatar
wow! i'll never tunr the ac off ever again!
Old Oct 22, 2005 | 08:21 PM
maxsin's Avatar
Windows up or down, our Xb's have serious wind drag issues. lol
Old Oct 23, 2005 | 12:36 PM
mikem53's Avatar
Ah.. good point...
Old Oct 24, 2005 | 03:20 AM
gslippy's Avatar
I keep the AC on all the time for dehumidification purposes and cooling when hot out. Can't say I notice much difference when I switch it off - maybe a slight increase in power.
Old Oct 24, 2005 | 11:43 AM
PaganGuy's Avatar
I'd still like to know how anyone can get 34+ mpg in this box. I've never got better than 32.
