Door panel removal
Old May 2, 2005 | 04:11 PM
special_k810's Avatar
Default Door panel removal
How exactly do you remove the front door panels. I saw a post that said take out the two screws and pull. I have removed the two screws, but it seems my panel is on pretty tight. I tried to pry of some sides with a screwdriver but the panel does not budge much. I am afraid to exert more pressure on the panel in fear of breaking some pieces. Is there a certain part of the panel that should be pried off first? Thank you in advance for any help.
Old May 2, 2005 | 05:09 PM
andrewjc's Avatar
Look here for a post from kgzero https://www.scionlife.com/forums/vie...376&highlight=
Old May 2, 2005 | 05:21 PM
M-Flo's Avatar
^^ yea that's an excellent write up on how to remove the door panels.
I would also reccommend getting a door removal tool to make it much more easy and painless to do. You can get it at most auto stores.
Old May 2, 2005 | 05:24 PM
Thanks for the post. I was just out at my car and took off the door panel with some info from djct_watt. I did not however remove the door handle first. Because of this I could not disconnect the other wires, so I was trying to hold the door panel up while I was disconnecting the side mirror wire harness. Thanks again for your response. It will come in handy when I will be installing my new side mirror.
Old May 3, 2005 | 05:32 AM
djct_watt's Avatar
Team Sushi
You don't need to remove the handle. . . just the switch panel. . . and the wire harnesses are right there.
And you shouldn't have to undo the mirror harness if you are simply removing the door, only the switches.
idriveanxa
Mar 8, 2015 12:03 PM
lunchbx05
Dec 29, 2014 07:53 PM
Joeynenj
Nov 25, 2014 05:29 AM
BlueBox
Mar 14, 2008 08:54 AM
swtbabiboi4u
Jan 4, 2004 04:03 PM
