required maintenance light
Old Nov 22, 2005 | 06:17 AM
kiyofox's Avatar
Default required maintenance light
The last 2-3 times I've started up my xA the "REQUIRED MAINTENANCE" light has come on blinking.
I'm not exactly sure what it is telling me needs to be checked tho. Now, my ODO is very close to 10k miles (time for the second oil change). Is the car "smart" enought to know that it needs an oil change at 10k miles, or what??
As far as I know there is nothing else that could be triggering the light.
What other things should I be on the lookout for?
Old Nov 22, 2005 | 06:49 AM
IllNist's Avatar
you shoulda had a second oil change a long time ago.
Old Nov 22, 2005 | 07:38 AM
kiyofox's Avatar
why?
Toyota says that you only need an oil change every 5k miles. I had the first one done at 4.5k. At 10k it would normally only be the second oil change.
Old Nov 22, 2005 | 10:40 AM
flyerI's Avatar
5000 miles is normally OK. It is time for a change. Check your manual. It tells you all of this.
Old Nov 22, 2005 | 12:52 PM
Theglen10's Avatar
The "REQUIRED MAINTENANCE" light comes on every 5,000 miles to remind you to change your oil. Press the odometer button and turn the key to the on postion and wait for the odometer reading to count down and stop blinking. This will reset the required maintenance light. If you want more info on how to do this.......READ YOUR MANUAL.
Old Nov 22, 2005 | 08:37 PM
lalagimp's Avatar
Why don't people use the Search Function?
This has been covered again and again.
https://www.scionlife.com/forums/vie...nance+required
Old Nov 22, 2005 | 09:14 PM
socalscion's Avatar
relax its just the required maintenance light
at least its not the check engine light
Old Nov 23, 2005 | 01:47 AM
sexyscionlover's Avatar
repost. look at lalagimps post for where to go
ndillon
Jan 26, 2015 04:28 PM
scsteven
Jan 25, 2015 01:06 AM
WhiteToaster
May 19, 2004 01:32 AM
