UPDATE: need help ASAP!!!!....car is fixed
so my car is in for warranty right now because of a check engine light related to clylinder number one misfiring. they now believe it is a bent valve so they have to disassemble the head. the problem is, they are making me sigh an agreement that says if warranty doesnt cover it because of possible abuse or modification, then i will have to pay the labor of $900. the problem is they say that if i abused the engine, due to overrevving (which the service rep says in our engine will very commonly make the pistons slap the valves, causing them to bend) or if i modified/tampered with it, warranty is void and i have to pay it. but what voids the warranty? he told me that there are signs that i have "tampered" with it. he says rounded off bolts and such. i told him that i have opened up the intake box to look at it, but that wont void the warranty. the only other thing i have done is that i have removed the valve cover. can they blame that on me saying that it causes my check engine light. i need to know asap because i am going in tomorrow morning to sign the papers. if i sign, i run the risk of them knowing that i have ran nitrous. if i dont let them, they will automatically know that i did something, most likely flagging the car. HELP PLEASE
ok i dont see how that helped ^ of course he did... he wants help
i would go in there, sign the papers, and bite the bullet and hope your good. worst comes to worst, you can fight it. all of this stuff will probably be up to the head tech as to whether its covered. unless its blantantly obvious that you messed it up, then theres always some "gray space" where its just the techs opinion. then maybe it could get thrown out. i would just say sign it, and pray
you've got my prays. best of luck. Scotty
Originally Posted by andersg
You just told everyone that you modified it in a way that would void our warranty
I don't know anything about Nitrous but maybe some residue from it could be left in the cylinder heads or somewhere along the block. I'm sure if they did some DNA testing on the block, they'd find it. lol
what they said ... um btw hope the head tech doesnt read this board ... as this is not a common malfunction of this motor ... um daaaa....
and besides putting n.o.s. system on a 108 hp motor ?? thats like buying a moped to race a porsche ... wtf?
thats not that much. and ya, it made it run a little bit harder for what 20 seconds at a time? its probably not even going to be noticed. if you drag raced the ____ outta it maybe.... but for the most part it should just look worn, not abused
This post = dumb. You ran nitrous and you think you can cake walk this???? OMG are you high? They will totally know, if they don't already. They are setting you up to take the blame by signing such nonsense. They just want YOU to take responsibility.
Come on! To ruin such a small engine like this can not happen stock. Or if you did screw it up, it still is your fault and has nothing to do with warranty... wear and tear....
Take it like a man. You aren't going to get away with this unless you are a total kiss ___ and smooth talk your way out of this saying ____ like your dog just died and you are dying from a rare disease in less then a month and all you wish for is your tC to be fixed. You have a smoking gun and they totally know it.
My dad said that it would cost them way too much money to even be able to detect the nitrous b/c of how clean it burns. I wouldnt mention anything about the nitrous b/c they wont find any evidence unless they spends thousands of dollars on getting it tested.
That is not true. they can plug and play the ecm and know what the hell was going on.
they are not going to be able to tell that there was nitrous used in the system as I said. In the case of the ECU they might be able to tell that there was a sudden burst of energy in the engine or some parameter may not seem right but they are going to need some concrete proof (like nitrous) to prove that it was a shot of Nitro that caused. Coulda been a sudden burst of energy from having to rev??
see the problem is that if you look under your warranty, it states if you "abuse" your engine that it will void the warrarnty. so they can basically void my warranty based on the assumption that i "abused" my engine...ie any sort of stress on the internals of the engine.
also, the ecu is a closed loop so it resets itself to the factory settings. meaning if i do boost and the a/f ratio changes, it will reset it. therefore not being able to read use from the ecu.
toyota has fullproofed their warranty. anytime they want to void it due to "abuse" they can just say that it was over revved or driven to hard and *poof* no more warranty
And don't we have a rev limiter? Shouldn't that protect against this? Make them explain why it wouldn't...
As for having you sign the estimate, they will do that on most repair visits. I don't think it's a set-up. When you take your car in for many things, they will write an estimate of like $100 in case its not covered under warranty. Time is money...
i am pretty sure we have a rev limiter. unless he took it off or reprogrammed the ecu. sounds like he knows what he is doing....somewhat....kinda....sorta.....maybe
So you're trying to get Toyota to fix your car for free even though you willfully modified your engine in a way that voids the warranty? What was it again you needed help with?
