will this cause airflow problems to the engine ? need answer
Old May 4, 2005 | 02:35 PM
Soon2BxB's Avatar
Default will this cause airflow problems to the engine ? need answer
what would happen if you were to shave both of the lower honeycomb grills on the xB
would that cause air flow issues to the car .. would the engine become problematic ?
i know that they are there for a reason but are they REALLY that nessecary ?
thanx
tom
Old May 4, 2005 | 02:44 PM
UnFocused's Avatar
yes you do! Common sense tells me that right behind those grills sits the radiator. Im guessing that the radiator needs air to cool the enigine
Old May 4, 2005 | 02:58 PM
Soon2BxB's Avatar
well it appears from looking at pics of the NOBLESE that you could at lease shave the middle one ... also look at the pic of the kit .. u cant tell me the radiator is sitting as low as that opening ...
notice that there is only one opening for the air flow there
Old May 4, 2005 | 03:00 PM
Scott17's Avatar
StyleWagons
Hell yeah you need these openings. The car will overheat if you don't.
Old May 4, 2005 | 03:12 PM
Soon2BxB's Avatar
dont be fooled into thinking im an idiot that dosent understand how airflow and radiators work
my question was merely .. are the honeycomb holes mostly there for looks (apparent by looking at the noblese and other kits)
it appears that both of them while they serve a purpose .. are not 100% nessecary as there are plenty of kits with only one opening for air flow
Old May 4, 2005 | 03:17 PM
luvmyxb's Avatar
What do you mean by 'Shave". I replaced both of my lower grills with a material that has smaller round holes closer together than the honeycomb. No overheating here in FL.
Old May 4, 2005 | 03:21 PM
Soon2BxB's Avatar
shave as in fill them in... both or 1 .. im getting my car painted and just seeing what things i could do while its in the process
Old May 4, 2005 | 04:17 PM
UnFocused's Avatar
well, When you said "shave" - that implys to me that you are covering up those openings.
You could probably do something custom, and still allow some airflow in...
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
Greg S
Feb 19, 2015 07:17 PM
hotroddelux
Dec 3, 2014 11:33 PM
k1114
Nov 30, 2014 01:40 AM
eric_m
79
Mar 17, 2013 12:21 AM
