Brighter reverse light solution... FINALLY!!! (56K beware)
pretty cheap and amazing mod. so now u can put an HID back there?
I couldn't find the parts anywhere, so I just picked up an H8 on eBay for $12 with free shipping. It's got a nice white color to it: http://tinyurl.com/c4gor2
I guess I'll have to get the harness online too. If I end up with a two-pack I'll offer the extra one up here.
Originally Posted by CIONIDE
Hey Fred, appreciate all your efforts, but is it possible to throw up some pics of the original bulbs light output vs. the new set-up?
Maybe pics of a wall or fence or something being lit up from a short distance.
It looks like from your mod that you can swap between the two quite easily, unless I missed something.
7440
H8
7440
H8
Originally Posted by ScionFred
I felt like the monkey with his hand stuck in a cookie jar trying to fish the bulb out with a fat finger...
My harness came in the mail yesterday but they sent an H13 harness. The "company" I bought from seems to have the same SKU# for both the H8 and H13 harness. They're totally different! Hopefully they can get their heads out of their asses and fix their catalog. I should have just special ordered from Autozone. I've got everything but the harness ready to go. Can't wait to try this mod already.
Sorry, I'm feeling a little silly ATM... I'm really anxious to hear some feedback from others on this DIY mod.
Originally Posted by renegade4x4
Where is the cheapest place to get the h8 harness? Cool mod i want to try it!
Hi Fred,
This is the second DIY I've seen of yours (also TB porting) -- you're an adventurous guy
! Nice idea, I find the OE rear illumination pretty weak and I'm very sensitive to the idea of running into something behind me (especially on the passenger side when pulling out of my driveway, it's black back there at night -- guess I need a flood light
)! I'm sure I'll be making use of this idea!
Thanks
)! I'm sure I'll be making use of this idea!Thanks
Originally Posted by TrevorS
Hi Fred,
Thanks
If you really want a flood light, you could run a 12V fused lead from the battery or fuse panel to a relay and put a 35W HID in there instead. The H8 and H11 are similar enough that either should fit just as well after some trimming. I may do that at some point but this works pretty well for now. I'm glad you like it.
got it installed the other day. seems be alot brighter now. well worth buying the bulb. used a utility knife to cut the edges on the light to make the bulb fit. luckily i had a spare hid harness for the bulb and paid $7 for the bulb. great mod!!!
yup everything went good. easy mod for anyone to do.
It's too bad that a single H8 sheds only about as much light as the more common dual 21-27W BU light arrangement but at least it's twice as much light as we started with. If I ever get around to it, I may try installing a 55-65w halogen with a relay and dedicated +12v lead. I had considered using a HID but it doesn't make much sense for this application considering the warm-up time required.
