Brighter reverse light solution... FINALLY!!! (56K beware)
Old Jul 13, 2009 | 07:24 AM
  #61
ScionFred's Avatar
AutoZone.
Old Jul 13, 2009 | 09:52 AM
  #62
XBinRochester's Avatar
Great Mod! I plan on doing this soon. I'm a newbee here and I had a question about your post (and many others). I keep seeing "56K beware", what does that mean?????
Old Jul 13, 2009 | 10:06 AM
  #63
ScionFred's Avatar
"56K beware" is a warning for those with limited bandwidth internet connections. Means the thread contains large photos which take forever to load on dialup.
I'm glad you like the H8 mod.
Old Jul 13, 2009 | 11:17 AM
  #64
Thanks for the fast response. That makes sense!!!!! I kept thinking it had something to do with the mileage and that didn't make sense at all! LOL
Old Jul 13, 2009 | 11:56 AM
  #65
elwaylite's Avatar
AutoZone.
Thanks!
Old Jul 14, 2009 | 10:45 AM
  #66
AutoZone.
My AutoZone doesn't carry the H8 lamp or the connector. I found the H8 lamp at Advance Auto, but they also don't carry the connector. I did find the connector online, so I ordered it. Can't wait for it to come in!
Old Jul 14, 2009 | 11:44 AM
  #67
elwaylite's Avatar
Hmmm, might just order it online then.
Old Jul 16, 2009 | 09:28 AM
  #68
ScionFred's Avatar
IIRC the harness is the same for H8, 9, 11 and some more. It seems that stock items vary by region and store but the Autozone in Glen Burnie, MD has the harness and H8 bulbs.
Old Aug 19, 2009 | 06:43 PM
  #69
Slody4Futbol's Avatar
thanks for the writeup! just did mine.. ordered my h8 and the harness from autolumination.com when i was ordering my g/f's replacement headlights.. took me 20 minutes to install.. i'd say it looks better but it's 90 degrees and bright sunshine outside so i can't really tell haha
Old Jan 23, 2010 | 08:28 AM
  #70
ScionFred's Avatar
9 months and still working great bump.
Old Jan 23, 2010 | 08:50 AM
  #71
A-snell's Avatar
Parts required:
One (1) 35W H8 halogen bulb ----------$15
One (1) H8/H11 socket and harness ---$10
Two (2) Scotchlok connectors ---------$1?
Electrical tape -------------------------$1?
RTV silicone ---------------------------$3?
a brighter reverse light?? PRICELESS
there's somethings money CAN buy.... for everything else? there's friends..
Old Jan 25, 2010 | 10:21 PM
  #72
TrevorS's Avatar
Definitely a great mod Fred -- thanks for taking the time to figure it out !
Old Feb 7, 2010 | 05:03 AM
  #73
LEDmod's Avatar
I'm planning doing a HID reverse light, I finally got around to get a timer switch... (turns one after like 1 second, protection for who has auto.. which turns on reverse light everytime you shift)
Is H8 would be best fit size?? any other size you recommend??
Old Feb 9, 2010 | 12:59 AM
  #74
ScionFred's Avatar
Thanks for the compliments guys.
H8 is the closest fit I could find. You only have to shave a little off the housing for it to fit. Are you going to run new wires for the HID? The oem wires should be fine once the HID is warmed up but I'd be a little concerned about the 150-200W draw to ignite and heat the bulb.
Old Feb 9, 2010 | 01:14 AM
  #75
LEDmod's Avatar
I'm using ballast with soft start. Draws less than 10amp at start up.
Worst case scenario, I can run a separate wire.
But my ballast will be fine with stock wire.
Old Feb 9, 2010 | 04:03 AM
  #76
ScionFred's Avatar
You're probably right. Although the oem wires are only good for <5A, the duration of the 10A load is very short. Probably not long enough to overheat them before the load drops to 3A. The timer is a great idea. Good luck with it and please post some pics when it's done.
Old Feb 18, 2010 | 01:23 AM
  #77
KaneoheKoa's Avatar
Wow, it looks like I'm not the only one who's underwhelmed by Scion's reverse light design!
Old Feb 18, 2010 | 03:32 AM
  #78
TrevorS's Avatar
Personally, I kinda like the quirky single lamp design, but Fred hugely improved it. The OE bulb is just fine for people seeing me, but the H8 makes all the difference when it comes to me seeing !
Old Feb 18, 2010 | 04:00 PM
  #79
Clever...'s Avatar
Cool
google HID reverse light Scion Xb.. You'll laugh like i did...
Old Aug 27, 2010 | 06:37 PM
  #80
NDSYSIV's Avatar
I got my H8 bulb from my local Honda dealer, it's a factory replacement for a fog light on the Oddesy and it was only $8. Cheaper than anywhere else I looked surprisingly enough...just my .02
