I'm a dumb...
Old Jul 12, 2011 | 08:19 AM
Kingshawty12's Avatar
Default I'm a dumb...
Ok so I got some new white non led daytime running bulbs for the xb. The purple ones died. I put the right one in no problem, the left one felt weird when I was putting it in the socket thing. I was twisting it into the headlight housing until.... It fell out of the socket and Into the Bottom of the headlight housing -_____-. Only way I can think of getting it out is removing the whole headlight and shaking it out. So for that whole wall what I'm saying is I'm a dumb___ and does anybody know where I can find a diy for removing the whole headlight? Btw the wires On the drl are loose in my vehicle causing them to Flicker, I am planning on taking it to Toyota for warranty but I'm afraid the aftermarket bulbs may void it -___-
Old Jul 12, 2011 | 03:39 PM
xseveredveganx's Avatar
Utah Scions
We have daytime running lights?
Old Jul 12, 2011 | 04:01 PM
jnaval's Avatar
I think he's talking about the new parking lights on the 2011MY xB2s, above the amber turn signals.
Old Jul 12, 2011 | 05:26 PM
flyingemu05's Avatar
http://www.clubxb.com/forums/showthread.php?t=31235
its a headlight blackout thread but it has all the steps to remove the bumper and headlights. its for 08-10 models but im guessing it should be the same for the most part.
Old Jul 12, 2011 | 08:38 PM
EDDIEA123's Avatar
I felt like a tard when that happened to me. I had to use some double sided tape and a clothes hanger but that wasnt too effective. I eventually decided to remove the whole light
Old Jul 12, 2011 | 10:22 PM
Do we have to take out the whole bumper?? -__- Ugh we do the other bolt Is under the bumper cover fml, but the bulb does look great though!
Old Jul 12, 2011 | 10:23 PM
Yup above the Ambers, only for the 11s and 12s if they are out already
Old Jul 14, 2011 | 07:51 AM
wadles143's Avatar
Id love to see a pic of that bulb set in twilight. Got my 2011 and took the front end apart like 6 times to do the custom led on the front end. Working the back this week. Did you use solder or taps? For exterior, u gotta use solder or at least heat shrink and then tape and use the shield tubing. Otherwise moisture will get in there. Think about it. Ambient air is like 70-110° F and engine temps are much higher. Heating and coolin of air and the wires= condensation. Not a bashing, just my .02 FWIW. Aloha!
Old Jul 14, 2011 | 03:05 PM
Estate's Avatar
yes the whole bumper needs to be removed if you're looking to shake it back out, its a good chance to paint your housing too if you haven't done it
Old Jul 14, 2011 | 06:15 PM
colinantherus's Avatar
i had the same thing happen to me when i was putting in my blue led parking lights. my bulb fell into the housing. i took off the front bumper and took out my headlight then i started shaking haha
Old Jul 15, 2011 | 05:13 AM
haha this isnt any custom work, its just plug and play. you know pull the old bulb out and put the new one in.
ill try and get pics tomorrow
Old Jul 16, 2011 | 06:38 AM
Thanks for the guide! We didn't pull the whole front bumper off just enough to get the bolt off and wiggled the headlight out. I had my moms friend come over for a little help but mostly to stare at his VIP gs400 on trafficstars <3 Got the bolt out and put everything right back in. And reinstalled the bulb, this time I made sure it really was in. Now they are even and white, no white and no purple led xD
Keffer69
Nov 16, 2014 01:04 PM
DarkNinja
Scion tC 1G Aero & Exterior
24
Jul 21, 2007 08:07 AM
BLAZIN
Jan 10, 2007 05:34 AM
jct
May 31, 2006 08:28 PM
