Overhead console removal
Old Aug 17, 2022 | 04:53 PM
bicepeak1's Avatar
Default Overhead console removal
How do I remove the overhead console without breaking it. I have a microphone on order and want to install it.
Old Aug 17, 2022 | 05:17 PM
Greg S's Avatar
Here's the install instructions. Removal will obviously be the reverse.
http://toyotaparts.sparkstoyota.com/...-12800inst.pdf
Old Aug 17, 2022 | 05:58 PM
bicepeak1's Avatar
Thanks, but it doesn't really tell me where to pry the overhead microphone cover / overhead light. The reinstall is part of the new larger console installation, which I am not getting.
I guess I could assume it doesn't matter where I pry, since Toyota doesn't specify where to pry in those instructions. Maybe I should try it before the microphone arrives so if I break it , the new one will be on it's way.
Ok I pried it, mostly from the back side. It has some very sturdy metal tension clips.. I was expecting plastic , and easily breakable, connectors. I easily snapped it back in place. Thanks for you help.
Old Aug 18, 2022 | 05:20 PM
Greg S's Avatar
Ah, you meant the map light panel. Yeah, that just snaps off with some pulling, as you discovered.
hybrid86
Nov 9, 2009 06:19 PM
Russ Lyman
Scion xA Aero & Exterior
Sep 9, 2009 12:41 AM
Diversion
Scion tC 1G ICE & Interior
May 16, 2007 01:21 AM
donscion
Nov 6, 2006 06:40 AM
phoenixtc
13
Nov 29, 2005 07:47 PM
